Old 02-06-2012, 11:21 AM   #1 (permalink)
How can you prevent a smooth underbody tray from getting exhaust fumes inside?
Making a smooth underbody looks easy.
How can you prevent exhaust fumes from getting inside the cabin?
Maybe you should leave an open space at the rear?
Or maybe some vents?
Old 02-06-2012, 11:29 AM   #2 (permalink)
Just make sure the end of the exhaust pipe sticks out of the bellypan I would think would be enough.
Old 02-06-2012, 12:37 PM   #3 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 53.2 mpg (US)
That is all I did and I have had no problems with fumes. As long as your exhaust and floor aren't both rusted through you should be fine. Some folks with hotter exhausts than mine (gasoline fueled) leave out a channel of coroplast close to the pipe so the plastic doesn't melt.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
Old 02-06-2012, 12:57 PM   #4 (permalink)
'10 Kia Forte EX 2.0 - '10 Kia Forte EX
90 day: 37.29 mpg (US)
Unless there's a leak in the exhaust system, it shouldn't be a problem as long as the tailpipe isn't covered up.
Old 02-06-2012, 05:10 PM   #5 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
1. Have you looked at any of the smooth under belly panels posted on this forum?
2. Every car sold in america has to have exhaust tips that send the exhaust past the car.
Given those two statements I cant really understand your question.
Here is an example of a rear panel ( on my car.....see links in mt signature)
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 02-06-2012, 09:55 PM   #6 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
Don't worry about it.
