03-08-2017, 08:50 AM
13, 14 or 15 inch light weight wheels for 5 on 4.5'' or 4 on 4'' hub
This post goes hand in hand with this:
http://ecomodder.com/forum/showthrea...ire-34883.html
I know I said I didn't want to buy different rims and different hubs because I didn't think it was in the budget.
Well it's back on the table.
So I'm looking for light weight wheels.
I don't know if 13 inch tires can even handle the capacity I'm looking for which is at least 1,200 pounds per tire.
But I know 14 and 15 inch tires are good for that much weight.
Any one know good make, model and year combinations I should check into?
03-08-2017, 09:19 AM
home of the odd vehicles
The Following User Says Thank You to rmay635703 For This Useful Post:
03-08-2017, 09:39 AM
I did not know 145/R12 tires came in load range E.
03-08-2017, 10:21 AM
Our fork trucks come with 6" wheels that hold many tons
With enough $$$$ anything is possible
Another place to look isspace saver spares, I have a set of 13" on my c-car that are rated at1300lbs each, just as long as you don't drive fast they are fine
03-09-2017, 12:40 AM
I went and looked up how much those light weight honda civic VX wheels weigh, because they are 13 inch and supposedly very light weight for a car wheel.
They weigh just under 10 pounds.
I went to tractor supply because I know they usually have 13'' bare steel trailer rims on the shelf.
I grabbed one of the steel trailer rim's and weighed it, it weighed in just under 12lb.
Only saving exactly 2 pounds per side.
I can only get load range D on a 145/13. Which is good for about 1,600lb.
Looks at this point the 145/12R load range E is the winner with its low price and 1,600lb weight rating and the overall size I'm looking for.
06-20-2018, 07:28 AM
I have been using the load range E, 145mm wide 12 inch rim alloy 5 on 4.5'' wheels for a little over a year now and I am very pleased.
I really beat the heck out of my trailer. I have been using my little trailer with these wheels between 10 and 15 days per month, every month for the last year.
06-20-2018, 07:34 AM
Appreciate the update!
06-20-2018, 09:06 AM
Cyborg ECU
From my car's garage page, all for a Civic or the like...
Possible wheel swaps:
13" CRX HF OEM (higher RPM & just under 13lbs)*
13" Civic VX 8 spoke (higher RPMs but only 9.7 lbs.)
14" Civic HX 8 spoke (approx 11.75 lbs)
14" first generation Honda Insight (11lbs)*
14" Civic Hybrid 2003-2005 (approx 14 lbs)
14" x 4.5", 4x100, 46 Offset, 56.1 center bore (2014 Mitsu Mirage)
15" Mini Cooper R81 Imola 7-hole (12.1 lbs)
15" Mini Cooper R86 star-spoke (15 lbs)
15" Mini Cooper R96 7-spoke (13.8 lbs)
15" Enkei Classic J-speed (14.1 lbs)
15" Enkei RP-F1 (9.5 lb)*
15" Kosei K4R (10.7 lb)*
15" Konig Helium (11.2 lb) 40mm offset, hub bore 73.1mm*
15" Acura Integra GSR (94-95, 16lbs)
06-25-2018, 04:51 PM
#9 (permalink)
175/70/14 Michelin Defender. Load index 87 which is 1201lb at xx psi. I literally just had these mounted up for mine. I fully expect them to last a hell of a lot longer than these bs small trailer tires...
Mileage warranty is 90,000 miles for a 2200lb civic. I wonder what it will be for a 700 pound trailer?
And yes they are civic tires dismounted and put on amazon trailer wheels lol
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
06-25-2018, 05:15 PM
#10 (permalink)
I believe that my 12 inch load range E tires are shorter rated for 1,500 to 1,600 lb.
But 1,200 per tire would work for most people.
A free used civic tire on a used or new trailer rim would be a lot cheaper than my 12 inch tires.
