03-11-2010, 04:28 AM
How do "Performance Mods" effect a car's economy???
I accidentally stumbled upon this site and have become very intrigued with different ideas to improve my efficiency. I would like a car that can get good gas mileage but can still be pretty quick when needed. I would like to know if anybody has any insight as to how adding things like intake, headers, and/or exhaust to a car would impact its efficiency? Im looking to have a car make decent power while still maintaining the stock fuel injectors and fuel pump. Thanks in advance!
03-11-2010, 10:00 AM
...beats walking...
...it "takes" a certain amount of power to drive 55mph due to aero+rolling losses, so ANY improvements in power (HP) "making" ability--if bi-lateral--can likewise (usually) yield improvement in fuel economy (MPG).
NOTE -- by "bi-lateral" I mean something that's NOT just a "oneway" change, such as changing from smaller diameter carburetor jets (good for MPG) up to larger diameter jets (good for HP, but kills MPG).
...headers are a "give & take" situation--they "give" you power at the engine speeds where they "tune" but also "take" power at intermediate engine speeds...kinda like childrens' "teeter-totter" where one end is UP while the other end is DOWN but the 'middle' (pivot) location never changes...the process of "tuning" is a proverbial "...rob Peter to pay Paul..." situation.
03-11-2010, 10:20 AM
Almost fuel free!
Check out Autospeed's website, they have a few articles on setting up cars for both performance and fuel economy
Browser Warning
03-11-2010, 04:42 PM
The simplest ways to get better power and economy are to reduce parasitic power loss. This includes things like manual steering conversions, AC deletion, use thinner grade motor oil, reduce exhaust backpressure, as well as non-engine work like weight reductions. Reducing weight could be as simple as cleaning out your car or replacing a spare tire with a can of Fix-a-Flat to more expensive measures like fiberglass/carbon fiber hoods.
Power and economy can work hand in hand, but if one is going for maximum fuel mileage, power must be sacrificed.
In Reason we Trust
03-11-2010, 05:10 PM
Better efficiency on today's gasolines?
Have you ever wondered what this "gasoline" actually contains (or doesn't contain) per unit volume? I'm not looking to start a firestorm here, but has anyone smelled this "stuff" as you pump it into your gas tank? Smells oily to me.... Gasoline used to smell sharp! Comments?
03-11-2010, 10:25 PM
RaceJeep - '98 Jeep Grand Cherokee (ZJ) 5.9 Limited 90 day: 13.62 mpg (US)
Performance mods can help FE. Some, such as roller rockers, free up parasitic power loss, which helps both power and mpg. Others, such as exhaust, reduce pumping losses. If you get a set of headers well tuned for low end and midrange, you'll gain low end torque, and possibly FE. You can also tune the computer for good performance when you put your foot down, and be efficient at part throttle (more timing = more power and FE, but needs higher octane).
Call me crazy, but I actually try for mpg with this Jeep:
Typical driving: Back in Rochester for school, driving is 60 - 70% city
03-11-2010, 10:47 PM
EV OR DIESEL
As a rule anything that moves the powerband up will hurt FE, this includes but is not limited to headers, cams, intakes.
Any reductions in parasitic loss will help, but keep in mind where they save x hp.
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
03-12-2010, 12:04 AM
Tank - '76 Chevy El Camino Classic 90 day: 25.89 mpg (US) Sabrina - '91 Mercedes Benz 190 E 90 day: 37.07 mpg (US) Angel - '88 Mercedes-Benz 420SEL Last 3: 23.01 mpg (US) Quicksilver - '04 Mercedes-Benz CLK55 AMG Cabrio
Whoah WHOOOAH DUde I'm all for performance parts Everyone knows that but i found one HUUUGE gap in your logic *Reduce Exhaust backpressure*
Yes it can be good to an extent but you also have to add in how much torque you may lose from different exhaust mods, Which may add horsepower however if you reduce your torque then you have to give the car MORE gas to make it perform the same in bottom end from lights and such, So you can't just put out things like that without backing Trust me i know
Tank:
(No actual EPA numbers for car just used F/E numbers when i first got it)
03-12-2010, 12:08 AM
#9 (permalink)
One performance gain i've never heard of hurting FE is Advance your timing with running Higher octane fuel, I do it in my el camino i run 91 octane with advanced timing and it saves exactly 1 MPG
Tank:
03-12-2010, 12:09 AM
#10 (permalink)
EV OR DIESEL
reduced exaust backpressure will not help
2 reasons
1) the increased flow will be directly ofdfset with decreased throttle position.
2) reduced scavenging will bring the power band up.
2016 Tesla Model X
2022 Sprinter
2012 Nissan LEAF SV
