Old 07-29-2008, 01:34 AM   #1 (permalink)
Whitey - '05 toyota corolla LE
90 day: 28.91 mpg (US)
Send a message via AIM to blackjackel Send a message via MSN to blackjackel Send a message via Yahoo to blackjackel
How much more MPG would you get lowering your car 2 inches?
I ran an estimate of 1 MPG gain, and I calculated that it would take me 70 tank fillups to justify a $100 cost of lowering my car by two inches (springs).
If it saves just 2 MPG then the figure would half!
How much improvement in FE do you guys think I'll see by lowering my car?
Here's my math:
100 gallons x 1MPG saved = 100 miles (saved per 100 gallons spent)
100 miles (saved) / 42 (my current average MPG) = 2.38 (gallons saved per 100 gallons spent)
2.38 gallons (saved) x 4.5 (approximate current cost of gas) = $10.71 saved per 100 gallons
$100 (approx cost of lowering) / $10.71 ($ saved) = 9.337 (amount of times you need to save $10.71)
9.337 (amount of times) x 100 (gallons) = 933.7 (gallons before the mod pays for itself)
933.7 gallons / 13 gallons (current tank capacity) = 71.823 (tankfuls before the mod pays for itself)
Old 07-29-2008, 02:32 AM   #2 (permalink)
Johnny 5 - '81 Honda Cm400e
90 day: 42.86 mpg (US)
Da bike - '06 Honda Shadow Vlx deluxe
90 day: 59.47 mpg (US)
how about this lower your car for looks then the change for mpg wont matter as much
Old 07-29-2008, 03:19 AM   #3 (permalink)
Ecoformance Engineer
Vince-HX's Avatar
EJ7 - '96 honda civic Hx
Last 3: 58.02 mpg (US)
my civic has struts and springs and they allow me to corner faster which really helps my EOC on certain parts of my commute.
Btw you also should include the cost of a re-alignment If you decide to mess with your car's suspension.
70 mpg or die modding
www.full-race.com
looking forward to seeing what kind of uber-sipper slinks out of the full race skunkworks.
Old 07-29-2008, 03:25 AM   #4 (permalink)
re-alignment?
Old 07-29-2008, 04:52 AM   #5 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
blackjackel -
Originally Posted by blackjackel View Post
re-alignment?
Because someone will be disassembling the suspension to install the shorter springs, you will need to get the wheels realigned :
Wheel alignment - Wikipedia, the free encyclopedia
You estimated $100 for the installation. If your estimate doesn't include alignment, you may need to increase the installation estimate to anywhere from $150 to $180 total.
CarloSW2
American Solar Energy Society
Old 07-29-2008, 01:10 PM   #6 (permalink)
Nevertheless, he has a valid question. Does anyone have any numbers before/after lowering?
Old 07-29-2008, 01:30 PM   #7 (permalink)
90 day: 51.82 mpg (US)
Ivan: not that I'm aware of.
Also, the in/effectiveness of lowering will vary from car to car as well.
blackjackel: you should add your vehicle to the garage so everyone knows what kind you're referring to in all your posts (it'll appear under your username).
Old 07-29-2008, 01:31 PM   #8 (permalink)
Alignment is free.
Pelican Technical Article: Home Alignment
Old 07-29-2008, 01:34 PM   #9 (permalink)
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
I lowered my truck 3" in front and 6" in back. In addition I went to smaller tires up front to get another inch.
My truck went from 76" tall to 72" tall and I gained 1.0 MPG.
The truck also corners much better.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
Old 07-29-2008, 01:37 PM   #10 (permalink)
oldscoob - '87 subaru wagon gl/dr
90 day: 47.06 mpg (US)
I didn't notice anything upon my own experiments. Handling, maybe looks...
Car and Driver magazine ecomods a Pinto: MPG up +25% MetroMPG EcoModding Central 34 01-29-2014 07:00 PM
Smart Car MPG in the City Arminius General Efficiency Discussion 22 03-26-2011 07:00 PM
Active grill block idea holypaulie Aerodynamics 17 10-13-2008 09:31 AM
$500 and 30mpg car? possible? olderthanme EcoModding Central 6 07-15-2008 09:37 PM
Family car with good MPG? rykoala Off-Topic Tech 20 06-28-2008 11:22 PM
