Old 07-30-2010, 02:28 PM   #1 (permalink)
insane in the propane
Cloud Car - '96 Dodge Stratus ES
90 day: 39.15 mpg (US)
How to: reduce the rich condition of a cold start.
most cars today upon a cold start will run the engine rich to aid in starting and perhaps warming up the cat. if you can lean out the overly rich condition to make it more along the lines of 14.7:1 you will reduce fuel consumption during the warmup phase.
for this post i will be using degrees Fahrenheit.
i have found that if you change the resistance of the coolant temp sensor you can fool the computer into running the engine at any rich or lean ratio you want while (and only while) it is in open loop mode. on my car it runs quite rich when cold starting. this rich condition stays that way until the computer switches to closed loop. using a stopwatch and a obd2 scanner that monitors open-closed loop status, i have determined this takes about 3 minutes.
what i did was add a 2000 ohm 1/4 watt resistor in PARALLEL with the coolant temp sensor. this had the effect of increasing the cold water temp read by the computer by 30 degrees. now when i start the engine, it no longer gives a 1 second puff of black smoke upon startup. the engine runs just a touch rougher during the 3 minute warmup but it isnt a big deal to me.
you are probably thinking to yourself, yeah if i increase the temp by 30 degrees when its cold, then it must increase 30 degrees when hot!. this is not true and i will explain why.
coolant temp sensors change their resistance on a non linear scale. the resistance increases or decreases exponentially depending on wither its cooling down or warming up. my 2000 ohm resistor increases the temp read by the computer by 30 degrees when the engine is cold, but it only increases the temp read by the computer by 5 degrees when the engine is fully up to operating temperature. this means i can leave the resistor connected all the time and never need to disable it. i also have not had a check engine light caused by the resistor. i have driven about 5000 miles now with the resistor hooked up and have not had any problems.
the way you find out exactly what resistor value to use is by wiring up a potentiometer in PARALLEL with the coolant temp sensor. try to use a with a value of 10Kohms full and 0 ohms when turned the other way. this way you have a lot of wiggle room. the pot is available at rat shack for a few bucks. the second half involves a obd2 scanner which is capable of showing the computers instant open loop-closed loop status as well as showing an instant readout of the coolant temp sensor in degrees.
i dont know how to measure fuel economy gains from this mod but its got to count for something.
96 stratus "es" v6 auto-stick
supplementary propane injection
injector kill switch, alternator kill switch
Charging system voltage increased to 15.5V
secondary and tertiary 12v batteries in the trunk
on-board battery charger
lights converted to led's
potentiometer controlled tps for ign timing
welded straight pipe in place of cat-cons
removed egr
3 inch body drop
90psi fuel rail & -50% low volume injectors
run 15% diesel 85% gas
The Following 2 Users Say Thank You to C3H8 For This Useful Post:
RobertSmalls (07-30-2010), saand (07-30-2010)
Old 07-30-2010, 04:29 PM   #2 (permalink)
Phantom's Avatar
Blue Meanie - '02 Volkswagon Golf TDI
90 day: 48.52 mpg (US)
Wife's car - '05 WV Passat TDI
Rudy - '94 Chevy C2500
I just have a quick question the 3min warm up for the car is that from a cold start and idling?
Why I bring this up is my Grand Prix also takes about 3min to change over to Closed Loop, but I have noticed that if I start driving right away it changes over much quicker.
I move at the speed of awesome.
"It's not rocket surgery!" -MetroMPG
Old 07-30-2010, 04:44 PM   #3 (permalink)
yeah, 3 minutes is what it takes from cold start and idling.
and yes if you start driving right away it will change over quicker. but a lot of people like my self tend to let the engine idle for 20-30 seconds after a cold start to give things a chance to start working, and the oil a chance to circulate before putting load on the engine.
removed egr
3 inch body drop
Old 07-30-2010, 05:12 PM   #4 (permalink)
You have oil pressure almost immediately after starting an engine. I see no reason to idle. I just start and go almost immediately.
The Following 2 Users Say Thank You to Daox For This Useful Post:
Frank Lee (07-31-2010), NachtRitter (08-05-2010)
Old 07-30-2010, 06:03 PM   #5 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
Simple, clever, probably effective. I may have to try something similar.
How much did it increase your temperature reading when hot?
My radiator fan kicks on and off based on the coolant temperature reading. I only have a 5-10°F window between the radiator fan and the thermostat.
Old 07-30-2010, 06:16 PM   #6 (permalink)
Basjoos Wannabe
ShadeTreeMech's Avatar
The Van - '97 Mercury Villager gs
90 day: 19.8 mpg (US)
Lyle the Kindly Viking - '99 Volvo V70
90 day: 25.82 mpg (US)
I'd just start driving. A modern engine wil be ready for a load in the time it takes to put it in gear after starting. If you're worried about it much, just be easy on it for the first bit.
My car reads closed loop in a matter of about 30 seconds. Is your o2 sensor a wideband or narrowband? IIRC the wideband is a bit quicker to start reading.
RIP Maxima 1997-2012
Originally Posted by jamesqf View Post
I think you missed the point I was trying to make, which is that it's not rational to do either speed or fuel economy mods for economic reasons. You do it as a form of recreation, for the fun and for the challenge.
Old 07-30-2010, 06:36 PM   #7 (permalink)
Phantom's Avatar
Ok I just checked my car on the way home after sitting for 6hrs the car was reading the ECT (Engine coolant temp) at 100F the air temp was ~93F. I started driving as soon as I started the car it took 46.4sec to enter Closed Loop.
I'm not saying that this will be the same for every car but I do know that the fastest way to warm a car up it to drive it. In the winter the car can idle for ~13 min to get warmish or I can get heat out by driving 3mi.
Thanks for the info and remember the OL/CL stuff I'm going by is for OBDII it could be completely different on OBD1 or OBD1.5
Old 07-30-2010, 08:34 PM   #8 (permalink)
Hypermiling rookie
Laurentiu's Avatar
Opel Corsa B - '96 Opel Corsa 1.2 8V
90 day: 47.27 mpg (US)
VW Bora 1.6 16V - '02 Volkswagen Bora/Jetta
90 day: 35.84 mpg (US)
Well, the device could be rigged to a button ON/OFF, it would be possible , no ? Also , even better I would think you could put a timer in the circuit, one that could be set to let's say 3 minutes. You start the car, the timer starts as well (like staircase-lights) and then it stays on for that initial minutes you need a leaner burn, then turns itself off to avoid starting the radiator-fan at lower than needed temps.
I don't know, I'm not mechanically inclined so my idea might not work..
"It has been my observation that most people get ahead during the time that others waste" Henry Ford
Old 07-30-2010, 09:41 PM   #9 (permalink)
Left Lane Ecodriver
The Insight loves the heat, and I'd like to know why. You can get into lean burn much sooner in 90°F weather than 70°F, and I see an improvement in FE that air density alone can't explain.
I've been thinking about replacing my ambient air temperature sensor (an IMA system input) with a resistor corresponding to ~150°F. I'd like to find out if a coolant temperature sensor lie-box would also be helpful.
Now, Propane, if your 3kOhms adds 30°F during the summer, what's it going to do in the winter?
I'm also very curious about how rough my precious, sensitive Insight will run when it misjudges the coolant temperature. I guess we're going to find out.
P.S. 0 Ohm pot in parallel = instant CEL, yes? Coolant temperature sensor reporting absolute zero.
Old 07-30-2010, 11:47 PM   #10 (permalink)
Hyperlurker
daring4's Avatar
D-max - '04 Chevy Silverado Ls
Notch - '65 Volkswagen 1500 S
MTCHBX - '05 Scion XB
90 day: 40.41 mpg (US)
I'm gonna guess you didnt mean "absolute zero"! Mine dont go negative, but it is late and had nothing better to do than respond...
Disconnected Idle Air Control - for lower RPM after a cold start Lazarus EcoModding Central 19 04-15-2011 03:50 PM
Winter cold start & idling warm-up experiment MetroMPG Hypermiling / EcoDriver's Ed 17 12-17-2010 03:39 PM
Reverse Lights Not Working On Cold Start FastPlastic Off-Topic Tech 5 11-06-2009 12:58 PM
Starting to get cold... jamessw Hypermiling / EcoDriver's Ed 40 11-17-2008 08:43 AM
Why won't my truck roll start cold? extragoode Hypermiling / EcoDriver's Ed 8 05-25-2008 08:22 PM
