Old 01-05-2018, 10:14 AM   #31 (permalink)
Idling
I am wondering how much fuel a fully warmed up 4 cylinder engine that is in good condition uses. I don’t believe that shutting the engine off at stop lights is the best idea to save fuel. The reason I think shutting the engine off at stop lights is a bad idea, besides obvious safety concerns, is that a properly running car probably won’t use enough fuel idling at a stop light to be worth wearing out your starter, among other parts like the ignition switch, risking an accident, or putting the effort into shutting the engine off and restarting it constantly. Same with EOC. I do, however, shut the engine off at railroad tracks and drive thrus. But at stop lights, I just shift to neutral and let it idle. Do you agree?
Old 01-05-2018, 11:15 AM   #32 (permalink)
Thalmaturge
CHONK - '18 Honda Clarity
For a Civic, I've heard anywhere from 0.4-0.6 gallons per hour of idling.
Old 01-05-2018, 11:28 AM   #33 (permalink)
My cobalt (2.2 liter) is closer to 1/3 gph, coasting in neutral at 30 mph I'm in the 90s mpg.
Old 01-05-2018, 11:33 AM   #34 (permalink)
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
I've seen anywhere from 0.25-0.35 gallons per hour idling with a warmed up 1.5-2.0L Honda 4 cylinder. My Insight's 1.0 3cylinder is about 0.20gph.\
EDIT: This is measured via an OBD II dongle.
Old 01-05-2018, 11:40 AM   #35 (permalink)
If I remember correctly, my Scanguage shows about 0.23 gallons per hour.
The Following User Says Thank You to EcoCivic For This Useful Post:
Fat Charlie (01-05-2018)
Old 01-05-2018, 12:35 PM   #36 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
I never idle. I sometimes bump-start, sometimes use the starter. 244k miles. Original starter, original pressure plate, second clutch disc.
No idling for me, I like being in the #1 spots!
EcoModder Fleet list - EcoModder.com
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
Old 01-05-2018, 01:04 PM   #37 (permalink)
...beats walking...
A ScangaugeII will TELL you in numbers.
Old 01-05-2018, 01:08 PM   #38 (permalink)
I use one, but I question it’s accuracy. It shows identical fuel consumption when idling in D as N. How accurate is a Scanguage?
Old 01-05-2018, 06:09 PM   #39 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
So... all these manufacturers making hybrids that turn off the engine and regular cars that have stop start, they must be doing it wrong.
Old 01-05-2018, 10:27 PM   #40 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
Ford and BMW are on record stating that the stop/start break even period is 3-5 seconds.
The safety aspect is a dud. There's a red light/ stopped cars in front of you anyway - where are you possibly going to go?
On a factory S/S system, the engine will be running before you can put it in gear.
MPGuino can log fuel used idling:
That's 4.52 litres out of 55.65 for the tank or close enough to 10%. A non eco driver spends more time stationary so would waste even more idling.
Honda IACV explained TomO Off-Topic Tech 16 12-21-2015 01:49 AM
High Idle after EOC Devon Hynes Hypermiling / EcoDriver's Ed 3 03-26-2010 10:35 PM
Idle Speed Adjustment '89 Metro SirKeats DIY / How-to 7 02-08-2010 02:23 PM
Consumption at idle groar Instrumentation 12 01-17-2009 07:12 AM
Altered Idle Speed After Performing EOC Tango Charlie Hypermiling / EcoDriver's Ed 20 11-19-2008 12:41 PM
