Old 03-22-2011, 10:08 AM   #41 (permalink)
AC-DC enthusiast
mrbigh's Avatar
Dual-PWR PHEV - '04 Toyota Prius
Kopper - '79 Bradley Bradley GT-II
Exclamation Driver PC boards
Originally Posted by jackbauer View Post
Sorry I havent been keeeping up with this thread. So are there any suppliers for the vla module at this time?
Jackbauer
PM sent.
Prius Absolutum Dominium . ..........KOPPER
PHEV conversion since Dec 2006.. . .... .Future EV
. . . . . . . .CALCars # 27. . . . . . . . . . ..on the works now !!
Old 03-22-2011, 01:24 PM   #42 (permalink)
Originally Posted by MPaulHolmes View Post
I was thinking that same thing today. Maybe if we cut the stupid plastic off of one, and see what all those bulges are. It's got to be really simple. Some sort of transformer, and a few capacitors and resistors and who knows what.
if you want to build one, here's the data sheet, and schematic of it's layout.
http://www.galco.com/techdoc/prx/vla500-01_dat.pdf
i'm not suggesting this would be any cheaper, but i think it would be pretty simple to build each of the sub-systems in the chip and then connect them together. at least gives you an idea of what all would be required.
Old 03-29-2011, 01:01 PM   #43 (permalink)
Mr. Bigh:
I would like a pcb board,parts and VLA500 chip ( and anything else I need to complete a driver) mailed to:
John McManus,
Box 706,
Oxford, Nova Scotia,
Canada, B0M 1P0.
I will pay by paypal as soon as I get a total.
Sorry, but I'm blocked from reaching you through email. I also can't give you my email because I am blocked. Is there a way to communicate that will be accepted by this site?
John
Old 03-29-2011, 01:26 PM   #44 (permalink)
AC-DC enthusiast
mrbigh's Avatar
Originally Posted by rumleyfips View Post
mr. Bigh:
I would like a pcb board,parts and vla500 chip ( and anything else i need to complete a driver)
John
pm sent
Old 04-01-2011, 10:08 AM   #45 (permalink)
ReVolt Enthusiast
Originally Posted by isaac_alaska View Post
if you want to build one, here's the data sheet, and schematic of it's layout.http://www.galco.com/techdoc/prx/vla500-01_dat.pdf
The schematic shown on that data sheet link is for the interface, not the actual VLA500 module circuit.
For those interested in the VLA500 modules, Powerex is not the manufacture of them. A company called “Isahaya Electronics” (Hybrid ICFIGBT driver series) makes them for Powerex.
-Mark
Old 04-03-2011, 07:18 AM   #46 (permalink)
jackbauer's Avatar
Is there a schematic / bom available for the board?
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
Old 04-03-2011, 07:52 PM   #47 (permalink)
AC-DC enthusiast
mrbigh's Avatar
From the Powerex BG2a application text
Component Selection:
Designation Typical Value Description Example: Mfg./PN
D1,D2,D3,D4 0.5 A, 1000V VCE detection diode – ultra fast recovery ON Semi/MUR1100E
DZ2, DZ3, DZ5, DZ6 16V, 1W Gate Voltage Surge Protection 1N4745
DZ1, DZ4 30V, 1W Detect input pin surge voltage protection 1N4751
C1, C2, C3. C5, C6 1000 μF, 35V Power supply filter – Electrolytic, low Impedance Panasonic EEU-FC1V102S
CS 0-1000 pF Adj. soft shutdown – Multilayer ceramic or film** EPCOS B37979---------
CT 0-200 pF Adj. trip time - Multilayer ceramic or film** EPCOS B37979---------
R1, R4 4.7kΩ, 0.25W Fault sink current limiting resistor
R2, R5 3.3kΩ, 0.25W Fault signal noise suppression resistor
R3 4.7KΩ, 0.25W Fault feedback pull-up resistor
OP1, OP2 NEC PS2501 Opto-coupler for fault signal isolation NEC/ PS2501
CN1, CN2, CN3 MTA .100” Input and gate drive connectors* AMP 641216-6
* Remove the three unused pins on CN2 and CN3 to maintain appropriate high voltage spacing.
Recommended mating connector AMP CST-100 Housing P/N 770602-6 with crimp contact 770666-2.
** CS, CT are only required in certain special applications.
Old 04-05-2011, 10:41 AM   #48 (permalink)
Originally Posted by mrbigh View Post
Finally I have the parts that do go along the IGBT driver board for the Paul & Sabrina revolt controller board. Based on Powerex electrical design and Paul's PCB art layout.
I will be supplying the bare PCB @ u$s9.50 and the PC board with almost all parts, excluding the VLA500-01 and the 2 gate power resistors for u$s 33.25.
Gate resistors (R3 and R7) depend on the preferred IGBT to be use, values will be in the range of 1.5 to 12 Ohms, 2 Watts dissipation.
Parts will be supplied populated on the board but unsolder to minimize parts bagging, labeling and placement mistake.
The parts kit:
6 Zenner diodes
2 Ultra fast recovery diodes
5 resistors
2 Optoisolators
5 electrolytic cap.
2 right angle connector headers
1 straight connector header
3 header connector sockets
12 gold crimp/solder pins
All parts distribution will be handled by USPS flat rate mailers in continental USA.
International orders are welcome, inquire whiting.
Payment will be through PAYPAL.
Thanks for putting this together.
Just a couple of tard questions. How many amps is the driver good for? I have the P&S boards. This replaces the standard drivers for more amps with the DC open revolt? If am interested in 2 boards if it will handle at least 1000 amps.
Old 04-05-2011, 11:36 AM   #49 (permalink)
ReVolt Enthusiast
IGBT driver on wiki ???
To who ever has the artwork for this IGBT driver project.
PM me if you want it added to the wiki.
-Mark
Old 04-05-2011, 12:07 PM   #50 (permalink)
The Crimson Crawler - '04 Hyundai Elantra GLS
90 day: 36.71 mpg (US)
That would depend on your IGBT's. The VLA500-01 drivers are good for up to 1400A IGBT devices, so with 2 VLA's, you could put down 2800A as the theoretical limit of the controller.
I'd say a safer bet would be along the lines of 2000A or so.
The Following User Says Thank You to Nevyn For This Useful Post:
NashvilleEVFiero (04-12-2011)
