Old 12-24-2011, 03:32 AM   #61 (permalink)
Igor - '07 Toyota Aygo
90 day: 63.4 mpg (US)
Yes, calibrated against a navigator. I think I drove about 120 km so it should be accurate.
The wheels I tried was what I had at hand at the moment. I do think that 175/70-14 would fit as they have about the same diameter as the 185/65-15 but are narrower. Anyway since I don't get the desired result maybe I'll stick with the original 155 mm. I can't find any 165 that I want i.e. Hakkapellitta for winter or Michelin Energy Saver for summer. Otherwise I would probably had tried them.
Old 12-25-2011, 02:31 PM   #62 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Michelin's website lists 165/70 (5,3% bigger, T) and 165/65 (2,3% bigger, T and H) in 14" in the Energy Saver
MICHELIN Energy Saver | Pneus | MICHELIN
The Following User Says Thank You to euromodder For This Useful Post:
Sykomor (12-26-2011)
Old 12-26-2011, 12:40 PM   #63 (permalink)
I didn't see the 165 Michelin so thanks but right now I'm looking for winter tyres and have decided on Nokian Hakkapellitta R. Still have to choose between 155/65 or 175/65 or 175/70. The last experiment tank was not in favor of bigger diameter.
Old 12-29-2011, 01:09 PM   #64 (permalink)
The PRC.
How did you find the effect on acceleration or maintaining speed ? I think this is where Aygo's lose out. City driving only I can easily get an MPG into the 70s, as soon as I hit the motorway it drops to low 60s at best.
Old 12-29-2011, 04:15 PM   #65 (permalink)
It was noticeable but not a problem even with a passenger and some luggage, except on FE. I still don't know if it is the grater load on the engine or worse aerodynamics that caused the increased consumption. Now I have the conti winter tyres on and two of them needs to be replaced: 175/70 or 175/65? Or maybe stick with the 155/65.
Old 02-17-2012, 07:08 AM   #66 (permalink)
From fourth to fifth EcoModder Fleet list - EcoModder.com Damn cold weather. The two new Nokian Hakkapeliitta R doesn't seem to help either. I finally decided on the original size 155/65 as replacement for the Contis.
I have been forced to partly drive on faster roads on the other hand so I guess I shouldn't complain. And 90 days at 62.65 mpg isn't really bad.
Old 02-17-2012, 01:59 PM   #67 (permalink)
euromodder's Avatar
Nearly 63 mpg in the kind of weather we've had in Europe these last weeks, certainly isn't bad.
You can't expect summer mileage
Old 02-17-2012, 04:21 PM   #68 (permalink)
The PRC.
And I'm still stuck in the mid-50s albeit with traffic...
Old 02-17-2012, 05:28 PM   #69 (permalink)
And with gasoline prizes rising to SEK 15 per litre (8.45 dollars per gallon if my maths are correct) I'm glad I'm not in a SUV.
Old 02-18-2012, 07:07 AM   #70 (permalink)
The PRC.
Oh yes- happy about that.
