Old 04-19-2010, 02:44 PM   #11 (permalink)
The Geo - '93 Geo Metro
90 day: 45.16 mpg (US)
Originally Posted by Dave's Civic Duty View Post
So the consensus is this is one to maybe overlook?
yes
Old 04-19-2010, 06:42 PM   #12 (permalink)
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
From:http://ecomodder.com/forum/showthrea...html#post29996
1963, Walter Korff ( Lockheed Aircraft ) claims "A smooth,slightly crowned disc out to the sidewall ( MOON EQUIPMENT CO. ),on each side of the wheel, provides a big improvement. Covering the wheels and suspension with an envelope type body is better; smoothly streamlining the envelope is best by far."
It's a good one for sure as wheels make a big dent in aero. From a purely practical viewpoint, just start with the easy ones.
I would never discourage you from trying this though. If you did I'd be watching with interest. It's on my list of to do's.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
Old 04-19-2010, 07:10 PM   #13 (permalink)
darcane's Avatar
I think this would depend a lot on what type of car you are talking about.
A lot of Land Speed racing cars use inside wheel covers... but only the Lakesters (cars that have exposed wheels outside of the body). With a typical passenger car, only a small percentage of the wheel is below the level of the air dam (if any at all) so I would guess the gains to be so little as to be unmeasurable. For a truck that sits up a little higher and the wheels are a little more exposed, maybe. But then, the first thing you should do for mileage is lower it and put on an air dam...
My vote is: don't bother.
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
The Following User Says Thank You to darcane For This Useful Post:
Frank Lee (04-20-2010)
Old 04-19-2010, 08:34 PM   #14 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
I think this might work well with my rear drums. I could screw coroplast to the drum to fill the large gap between drum and wheel. That would be easier than trying to attach a fairing to the rear suspension. The wheels would still be easy to remove and install, and the cooling requirements of rear brakes, especially on a hybrid, are very modest.
Old 04-20-2010, 06:22 PM   #15 (permalink)
inside
Originally Posted by tollo View Post
Has anyone done wheelcovers "inside" the wheel ? Covers could rotate with the wheel, like with normal covers or the covers could be mounted with brake saddle. In some cases a big brake disk is some kind of "inside wheelcover". Any ideas ? It is quite obvious that inside covers would effect less than outside ones but how much less? Is there some disadvantage ? Control arms need some space so you can't never do full cover or can it be done at all ?
While these are used on land speed record cars, my opinion would be that the turbulence created by the proximity of suspension,steering links,and brake components would conspire together to defeat the effectiveness of the inner cover even if installed.
Even tire 'flop' requirements usually require belly pan clearance around a lower control arm which pretty much guarantees turbulence in this region.
And as others have already mentioned,brake cooling can be a serious matter,especially the replacement cost of warped rotors.
aero wheel covers? gone-ot Aerodynamics 2 04-06-2010 06:59 PM
OEM Near-Aero Wheel Covers Rokeby Aerodynamics 15 10-21-2009 11:37 AM
Stock inside wheel well covers and fuel economy? SVOboy Aerodynamics 6 03-28-2009 01:10 PM
Cheap-o Smooth Wheel Covers bennelson Aerodynamics 40 03-15-2009 11:55 PM
wheel covers: corugated plastic or taped hubcaps? modmonster Aerodynamics 4 02-08-2009 07:54 PM
