Old 09-13-2009, 06:21 AM   #1 (permalink)
"Instant" values bounce around?
Are mpguinos supposed to have stable Instant MPH, MPG, GPH, etc, readings, under steady driving conditions?
I'm still adding code to my mpguino & havent wired it into my car yet. For my testing, it's running on dcb's signal generator, which I thought should provide the most stable inputs possible, but my numbers are quite jumpy.
GPH ranges from 2.01 - 2.37, MPH is 93-100 (no, i'm not using the default #defines ), MPG is 35-48, RPM is 5300-5800. My Current & Tank data are all rock steady; the problem is only with Instant. Somebody's post about GPH going "0.12 0.12 0.12 0.15 0.12 0.12 ..." made me wonder if actual - rather than simulated - driving would produce stable figures.
I'm guessing the problem is due to vss & injector pulses landing on random sides of the 1/2-second sample window. (?)
Old 09-13-2009, 07:23 PM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
What version of the software are you using?
Old 09-13-2009, 07:43 PM   #3 (permalink)
0.75. I looked at 0.82 & didn't see a change in that part of the code.
Old 09-13-2009, 07:57 PM   #4 (permalink)
Dartmouth 2010
SVOboy's Avatar
In that case, I'm not sure. Mine was jerky on .69 but I heard about it being smoothed out, but I'm not sure for which update that was.
Old 09-13-2009, 07:59 PM   #5 (permalink)
So is yours still jerky? What version?
Old 09-13-2009, 08:05 PM   #6 (permalink)
Dartmouth 2010
SVOboy's Avatar
Still jerky on .69. I'm not sure if I'll ever update it so unfortunately I can't tell you if it did indeed smooth out for my computer
5 Cash for Clunkers Values on which to Spend your $4,500 SVOboy EcoModder Blog Discussion 10 07-30-2009 11:57 PM
Different usec / gallon values with no alternator? gascort OpenGauge / MPGuino FE computer 3 06-01-2009 09:40 PM
Bounce Test for Rolling Resistance? Ernie Rogers General Efficiency Discussion 14 05-25-2009 06:38 PM
looking for electric screwdriver drill torque values lunarhighway The Lounge 7 02-03-2009 08:41 PM
