Latest Tank in..
427.2 on 56.55l gives 34.34mpg IMP.
Some progress back up to the values I'm after
Have noticed that the car struggles to heat up in the colder mornings, so I think a full service inc thermostat replacement is due- would be good to get the coolant changed before the Winter creeps in.
going to order the stuff tonight
In other news, I got some new suspension for it
The dampers are Bilstein B8's- just about the best non coilover you can get for the e30, The springs are unknown (likely swap to whats fitted currently). They are £300 for a pair of fronts, and £220 for a pair of rears.
The 51mm struts they are fitted to are about £70 in their own right, and the Topmounts are e30 M3 ones, eccentric for more camber £100 a side
the struts have relatively new (18month) old bearings fitted. £40 a side
suffice to say, I didnt pay £860
I'm over the moon
Now I just need to get the Burd's car in for its suspension refresh before fitting these..
Also, I'm gearing up for a raid on B& Q for insulating strips to seal the grill
