Old 12-12-2012, 07:32 PM   #1 (permalink)
Newbie from DFW
Howdy. Newbie from DFW, north Texas area here.
Used to do a lot of street legal drag racing many moons ago. Also owned and operated a chassis shop. Got busy in other business and haven't done anything with cars in about 10 years.
I am a science teacher now and have a little interest in learning about increasing efficiency and looking at alternative fuels/forms of transportation.
I currently own a 2006 PT Cruiser Limited turbo, 2007 Jetta 2.5, 2004 GMC 2500HD(6.0 liter), and 2002 Hyundai Accent.
I can see there is quite a bit of information here so the learning curve is pretty steep. I am currently debating the possibility of building my own hybrid. I probably won't be posting very much until I spend some time reading/learning.
Looking forward to finding out what it is that I don't know.
Old 12-12-2012, 07:52 PM   #2 (permalink)
90 day: 19.36 mpg (US)
As a Dallas native, welcome. Moved away a few years ago and miss some of the techs and shops where I knew I could find good work and great advice.
What has worked well for me is:
1] Combine all trips. The DHS sez 90% of us go to 90% of the same places 90% of the time. I used MAPQUEST "Best Order Routing" to analyze my usual errands. It is one thing to know to go to the farthest place first (via freeway if possible for a long easy warmup), but it is another to find right-turn only routing from thereon (as does FED-EX and UPS). The effort is worth it.
2] Now, having eliminated short trips and cold starts, the challenge is to drive the remaining miles as well as possible. I decided that changing my habits was crucial as I wanted things to be habitual. That is, I would use whatever methods adapted on a constant basis. It isn't enough to know how to do EOC or P&G, but that one must make them part of the routine of driving.
I've been driving for economy for 40-years, but that didn't mean that there wasn't room for improvement. Just beating EPA estimates is not hard (but it was enough for me for many years).
I highly recommend extensive records. The fuel log here is good to use. I record in a journal kept in the console. All gallons, and all miles. Any effort expended is all about changes to the baseline mpg: the percentage change.
Finally, it is worth every effort to mechanically baseline the vehicle. Don't assume that alignment or brake drag or steering wander, etc, is within boundaries, Spend a little to find out. Little things like posture, mirror adjustment, clean glass all add up.
FE is all about details. Many, if not most, are just a matter of making some lists (scheduled maintenance as a beginning) and checking things off as part of those records.
A big metro area presents challenges. Time and distance don't always equate as stress plays a big role in getting from Point A to Point B. The relaxed driver who has to give the least input to the vehicle to maintain best momentum is miles ahead.
Good luck.
The Following User Says Thank You to slowmover For This Useful Post:
Runum (12-12-2012)
Old 12-12-2012, 08:15 PM   #3 (permalink)
Thank you for the tips slowmover. I don't do much big city driving, mainly highway, outside of the gridlock.
Love spending time in Port Aransas too.
Old 12-12-2012, 09:30 PM   #4 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Welcome to the forum, Runum.
Runum (12-12-2012)
Old 12-12-2012, 10:34 PM   #5 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
Runum,
Welcome from a former Dallasite/OakCliffer !!!
Air up the tires!!!
ANd enjoy the info......almost as good as a PhD!
(these guys are SMART!!)
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 12-12-2012, 10:50 PM   #6 (permalink)
Thanks Metro and Mcrews.
I have actually been reading about your bellypan install and results. Good stuff.
The Following User Says Thank You to Runum For This Useful Post:
mcrews (12-13-2012)
