Old 08-12-2013, 04:13 PM   #1 (permalink)
libertyfrancis1's Avatar
slicksilver - '99 Honda Civic LX
90 day: 36.1 mpg (US)
speed racer - '01 Toyota MR2 spyder
90 day: 28.01 mpg (US)
K&N air filter vs. OEMs great tech data
Thought i would share this as everyone believes all the claims you see on TV or magazine adds.
Debunking the K&N Myth - Why OEM is Better : Nissan Articles
Just cant beat a WIX air filter for a few bucks
The Following 2 Users Say Thank You to libertyfrancis1 For This Useful Post:
Pawtuckett (08-12-2013), redpoint5 (08-14-2013)
Old 08-12-2013, 04:56 PM   #2 (permalink)
Busy Homeowner
So basically, if you need more airflow for your engine and don't want to retrofit a larger airbox to accommodate a larger paper filter, then you can use oiled filters, but only if you accept that you're allowing significantly more gunk in your engine and need to clean the filter regularly to maintain peak performance. Myself, I'm sticking with paper!
The Following User Says Thank You to Daekar For This Useful Post:
ksa8907 (08-12-2013)
Old 08-12-2013, 05:37 PM   #3 (permalink)
I read a test years ago by a heavy equipment mining company. they monitored everything down to oil analysis and precisely the amount of operational time each engine had when it had to be overhauled. Large Diesel engines. Turns out the aftermarket oiled air filters were killing engines at something like twice the rate of factory filters (won't mention brand). When you spend 50+k on a rebuild having your engines die in half the hours is a huge unnecessary expense.
I have never used personally or advocated the use of anything but OEM or equivalent filters since reading of that test. My Insight had one when I got it and the 02 sensor died at 36k miles. I would be willing to bet the over oiled filter was the cause of the bad 02 sensor.
regards
Mech
Old 08-12-2013, 07:29 PM   #4 (permalink)
Everyone... except EMers!
http://ecomodder.com/forum/showthrea...k-n-10523.html
libertyfrancis1 (08-13-2013)
Old 08-13-2013, 11:10 AM   #5 (permalink)
Thanks for clarifying that for me, i should have said the common person (non - ecomodder)
Old 08-13-2013, 11:00 PM   #6 (permalink)
clank - '99 jeep tj sport
90 day: 17.32 mpg (US)
i'll just leave this here
FAQ - Cold Air Intake - JeepForum.com
Old 08-14-2013, 02:05 AM   #7 (permalink)
90 day: 29.78 mpg (US)
I attempted to educate the Jeep crowd in a forum once, and was roundly rejected because someone that had been a bigger contributor to the forum disagreed with "my" science. He was an ASE certified grease monkey, which gained him enormous credibility with the Jeep idiots.
I've given up. People that make the poor decision to purchase a Jeep likely don't have the mental faculties to consider a well reasoned argument about fuel efficiency.
I argued that higher altitudes should increase fuel economy, and that cold air intakes will slightly reduce economy. It's here if you want to see a troglodyte discussion.
The Official "My Gas Mileage Sucks" Thread - Page 20 - Jeep Liberty Forum - JeepKJ Country
Old 08-14-2013, 02:22 AM   #8 (permalink)
Holy Hanna, I see what you mean.
And nothing makes posters look like a bunch of rubes as quickly and thoroughly as poor spelling and grammar, right? Right?!?
Old 08-14-2013, 02:36 AM   #9 (permalink)
and your post has what to do with the original topic or what i posted...
Old 08-14-2013, 02:39 AM   #10 (permalink)
That K&N users are meatheads?
