Old 09-13-2021, 09:32 AM   #21 (permalink)
What happened to the guy doing energy storage on the abandoned rail line in Tehachapi?
We had a discussion here a while back
Old 09-13-2021, 10:23 AM   #22 (permalink)
JSH
AKA - Jason
JSH's Avatar
90 day: 17.3 mpg (US)
And this is why those concrete blocks and that crane seem to not be so efficient at all.
Why? If (yes that is an unknown) Energy Vault can built full size units at the quoted cost they are far cheaper than any other grid storage technology listed in the Dec 2020 Department of Energy report I linked above.
Old 09-13-2021, 11:42 AM   #23 (permalink)
It's not so clear how lowering the blocks with a crane could effectively provide electric power. Would it require a special crane with some feature similar to the regenerative braking featured on hybrid cars?
Old 09-13-2021, 12:44 PM   #24 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 207.11 mpg (US)
Send a message via MSN to jakobnev
This was Thunder Busted a couple years ago:
Edit: Sorry wrong video, I meant this one:
Old 09-13-2021, 12:45 PM   #25 (permalink)
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
Originally Posted by samwichse View Post
Modern pumped hydro uses reversible turbines. No separate pumping system is used.
https://voith.com/corp-en/11_06_Bros...ge_einzeln.pdf
Engineering is all about trade-offs. It appears that the costs of doing separate pumps and turbines on very large systems out-weigh the increased efficiencies (from the graphs in the link)
I am guilty (again) of ASSUMING and being too LAZY to look it up
In THEORY there is no difference between Theory and Practice
In PRACTICE there IS!
Old 09-13-2021, 01:02 PM   #26 (permalink)
JSH
AKA - Jason
JSH's Avatar
That is exactly how it works. When the grid has surplus electricity you use it to run the electric motors on the crane and stack blocks. When the grid needs electricity you unstack blocks, gravity turns the electric motor which acts as a generator and produces electricity. Just like an electric motor in an EV or hybrid.
Energy Vault's key innovation is stacking lots of smaller blocks with an autonomous crane. By using small weights the lifting structure can be built with inexpensive off-the-shelf construction crane components.
Old 09-13-2021, 01:43 PM   #27 (permalink)
JSH
AKA - Jason
JSH's Avatar
Wow, that is an annoying bad video full of useless filler. I notice it is from 2019 - before Energy Vault built their 1/4 scale demo unit which was finished a little more than a year ago.
I really got a laugh when he said "there is absolutely no reason to have bricks on the bottom" (of the stack) because "The bricks on the bottom store zero energy" Why are there bricks there at all? LOL! Maybe because you can't have a stack of bricks without one of the bricks being on the bottom.
His basic argument is the pump storage is better and makes up 95% of grid storage. He seems to fail to see that we will need to add a huge amount of grid storage if we switch to renewable energy at scale and we are about out of places to put huge reservoirs of water.
Old 09-13-2021, 02:45 PM   #28 (permalink)
That's the reason I didn't watch it. Well actually it's his annoying voice crack on 'Welll...."
Joey Salads was on Tim Pool and when he wanted to slag on Elon Musk, he quoted Thunderfoot. I burst out laughing.
edit: I just realized where the idea for my 3D round house printer (with yards and booms) came from. It has a print head for pumped concrete, a pick-and-place arm for placing blocks and an impactor for a rammed earth floor.
"If you don't read the newspaper, you are uninformed; if you do read the newspaper, you are misinformed. " someone who was not Mark Twain
Old 09-13-2021, 07:55 PM   #29 (permalink)
Seems reasonable, yet I believe it would still need some chemical storage, either a battery pack or some capacitors which might be better suited to the quick discharge cycles.
Old 09-13-2021, 08:40 PM   #30 (permalink)
90 day: 28.24 mpg (US)
Lafawnda - '01 Honda CBR600 F4i
Big Yeller - '98 Dodge Ram 2500 base
Prius Plug-in - '12 Toyota Prius Plug-in
90 day: 57.64 mpg (US)
Mazda CX-5 - '17 Mazda CX-5 Touring
90 day: 25.04 mpg (US)
Yep, no getting around the need for instantaneous buffer to allow the continuous supply to ramp up. Fortunately that shouldn't need to be that extensive. 10 minutes tops?
