Old 08-27-2008, 06:39 PM   #31 (permalink)
Thanks for the detailed reply. I had forgotten about the good things I'd heard about the Volvo 850.
Regarding ride quality--I want straight-line comfort, a little mushiness is OK as long as it tracks OK and doesn't require constant steering correction.
Ray Mac
Old 08-27-2008, 06:54 PM   #32 (permalink)
ALS
The 850/S70 are not the greatest in fuel economy. Average is around 27-28 mpg highway. My brother owns a 99 S70 and I get 1.5 mpg better highway in my 960.
The fwd 3100 lb S70 has a 2.4L 160 hp I5 and is aero rated at .32 Cd. While my rwd 3550 lb 181 hp 2.9L I6 960 areo rated at .36 Cd.
Volvo is in trouble because their cars are not getting better mpg's
My 97 960 at .36 Cd gets the same mpg as a 08 S80 with a .28 Cd that replaced it.
This is the reason when I replace my 87 740 wagon DD, it will not be with a another gas hog Volvo.
Old 08-28-2008, 08:49 AM   #33 (permalink)
I have an 1998 Olds Delta 88 3.8 ( inherited from an elderly relative in 2004 with 24 k miles ) that was getting 22 mpg city and 28 mpg hwy . The mileage has dropped considerably of over time down to 17-23mpg . The car has had regular maintenance . A full scan ( with a real sacantool ) showed everything functioning OK . A tune up did not help . I now have about 71K miles on it and wondering what I can do . Any suggestions to get that mileage back ? - Thanks
Old 08-28-2008, 09:26 AM   #34 (permalink)
Neon1 - '97 Plymouth Neon highline
90 day: 27.26 mpg (US)
Rkpatt. If the mielage has dropped that much, there is something up. At only 71K on a 3.8 I would venture that it is a sensor out, and most likely one or more of the O2 sensors in the exhaust. There is a maintenance interval for these that (IIRC) is around 60K miles. They may still be "close enough" to not trip the scanguage.
That is assuming that you don't have a brake dragging or bearing going out that would not show up in a comuter scan anyway.
Back on topic....
Every vehicle that has been mentioned with good statements will not be too mushy on a straight drive, and bigger cars generally require less steering correction with their longer wheelbase on highway drives (I sometimes drive a jeep XJ and I see a LOT of steering correction ) Any of them are good, what it ultimately comes down to is drive what you are comfortable in, keep up on the maintenance and tune-ups, drive conservatively, and enjoy.
Jim
Old 08-28-2008, 09:35 AM   #35 (permalink)
Mushy is good!
American cars with a mushy ride are perfect candidates for stiffer and lower suspension. It's like a twofer you get the handling and improved Cd both in the same package!
Old 08-28-2008, 10:16 PM   #36 (permalink)
Renaissance Man
Formula413's Avatar
Aegean C - '17 Honda Civic LX
90 day: 39.01 mpg (US)
You could always try the old reliable Seafoam treatment. If there is significant carbon buildup inside the top end this would certainly have some benefit. How much of the car's usage is city driving? I would think bad compression would be unlikely at 71k, but anything is possible.
Old 08-29-2008, 11:38 AM   #37 (permalink)
Re the Concord
I took a 2000 Concord with the smaller six cylinder last year in part trade for a hotrod I had built and was selling off.
It is not what I would call an exciting car and normally I would not have considered it. The thing is I had just changed work circumstance and was going to be driving a sales route and occasionally sheparding around manufactures representatives to accounts. I am in the DFW area and have about 70 accounts all over the metro area and put about 150 miles a day on the car so I needed to get decent fuel milage obviously. But I also had to be able to pick up and carry around a few other sales weasels now and then, so I needed a fair amount of room. It turned out that the Concord was pretty much ideal.
Having had a Neon R/T and a PT Cruiser not long ago I was kind of luke warm on the Chrysler products, but the Concord has so far turned out to be a pleasant surprise. I am averaging just a whisker over 25mpg with combined driving and I can do 32-33 on the highway. Keep in mind that this is driving like a grandmother as opposed to my old leadfooted ways.
The car had about 110k on it when I got it and I have put another 25k on it in the months that I have had it so far. The only things that I have had to deal with are like another guy mentioned I replaced the crankshaft position sensor. I am told that this is not uncommon with these cars after a 100k or so. I also had some new brakes put on.... apparently the first set to be replaced as I have all the orginal records and they had never been touched.
While I know these things have very little personality and frankly look like the end of the probe an alien would use on you, the fact is that they are dirt cheap, get pretty good mpg for their size and they are pretty big. I look like a mountain gorilla that has been strategically shaven and jammed into business casual and I am quite comfy in it.
Would have rather had an Avalon I will grant, but given that I got it for the equivelant of 2k I think the car really has its points.
Just my two cents.
Funny that I have been lurking and reading forever and something like the Concord got me to start talking.
Cheers,
Crafty
Old 08-29-2008, 12:19 PM   #38 (permalink)
Yes, my daughter has a 2000 Concorde and it seems to be a good car.
When you say you have the smaller engine, do you mean the 2.7? I've read that the earlier ones had a design flaw that caused oil sludging and major engine damage. Hopefully if you have a 2.7 it's a later engine or one that's been taken care of (synthetic oil, etc.). The larger v6's did not have this problem and did pretty well on FE.
Ray Mac
Old 08-29-2008, 04:13 PM   #39 (permalink)
Legend in my own mind
trikkonceptz's Avatar
Evil Pumpkin - '08 Scion xD RS 1.0 #1633
90 day: 35.45 mpg (US)
Silent Silver Killer - '10 Honda Insight EX
90 day: 51.5 mpg (US)
I am close to inheriting a 2000 BMW 540. It is a large solid sedan V8 powered and very comfortable to drive. it is quiet and smooth. In fact with no alterations I had that bad boy doing 25mpg in the city and 32 on the hwy. It not only has a digital mpg meter on board but also has the vacuum meter in the console.
It feels and is a solid car and I am sure reasonably priced in todays market. I will be replacing my 4-runner with it asap. And for those who enjoy older technology still has a tape deck in it along with a cd player .. LOL
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
Old 08-29-2008, 11:46 PM   #40 (permalink)
Sludging....
Ray Mac
Yea it is the 2.7L, I don't know if there was trouble with the sludge building up in the first 100k miles. I was lucky enough to have gotten it after the original owner had gone through some kind of deal with a dealer where by he had a new crate motor installed. I got it at about 7500 miles after the install. So if the first motor had issues, the newer one does not seem to. I just do normal oil changes and have had the crankshaft sensor and the basic brake work done.... beyond that boring but dependable and a pretty good work horse.
Crafty
Article: Want cars to eat less? Put 'em on a diet MetroMPG General Efficiency Discussion 34 07-14-2013 01:38 AM
Cars compared in wind tunnel Bearleener Aerodynamics 30 08-26-2011 05:38 PM
News: GM's chairman - "small cars don't work in this country" MetroMPG General Efficiency Discussion 32 11-19-2008 06:50 PM
Bio-Beetle Rental Cars - "I felt like a celebrity!" MetroMPG Fossil Fuel Free 0 01-04-2008 09:21 AM
Article: Do Any Current Cars Meet the New CAFE Standard? MetroMPG General Efficiency Discussion 2 12-18-2007 03:03 PM
