Old 05-03-2008, 10:02 PM   #1 (permalink)
diesel mustang--how would you make one?
I'm thinking about making a 99 mustang a diesel? I'm not really sure if it's possible but I'm just brainstorming. So far I have heard that a diesel out of an old ranger would work but that's as far as I've gotten. I wonder what kind of motor mounts that would require and who would have them or would they need to custom made.
What kind of engine do you think would work best? I know a new VW engine would be awesome but I think the electronics would be a pain and it would require more additional parts in the drivetrain, i.e. transmission and driveshaft. Do I have any other options here?
Old 05-03-2008, 11:13 PM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
You would need to figure out about the mount issue, but if the engine/transmission could physically fit, you could have custom mounts make and just swap over everything, shouldn't be toooo bad.
Welcome to ecomodder!
Old 05-03-2008, 11:38 PM   #3 (permalink)
roflwaffle's Avatar
Camryaro - '92 Toyota Camry LE V6
90 day: 31.12 mpg (US)
Red - '00 Honda Insight
Prius - '05 Toyota Prius
3 - '18 Tesla Model 3
90 day: 152.47 mpg (US)
Are the engine bolt up points for the V6 and V8 the same? If they are, there may be factory options available, which will either cost a ton from an importer, or be an o.k. price if you don't mind going down to South America to track the right stuff down.
Old 05-03-2008, 11:47 PM   #4 (permalink)
pbryantr's Avatar
The Shamrock - '80 Volvo 245 DL
My ultimate dream diesel project is to put in a 7.3 Powerstroke in a mid-60s Lincoln Continental and then converting it to run on biodiesel or veggie oil. I think this idea would speak volumes to the concept of re-using/re-purposing old vehicles instead of discarding them in favor of newer cheaply-made vehicles.
Sorry about the random tangent. Anyway, back on topic: I second what SVOboy said about mounts and such. There's a guy on Turbobricks who transplanted a 1.9TDI into his Volvo 245. He said the biggest issues (both fabrication and cost-wise) were the mounts and tranny bellhousing adapter. Find thread here: http://forums.turbobricks.com/showthread.php?t=100369
Best of luck on your project!
Regards,
Bryant
Old 05-04-2008, 12:54 AM   #5 (permalink)
Saving Those Greenbacks
FX2.3's Avatar
Snowy - '02 Ford Ranger XL
90 day: 23.29 mpg (US)
Not sure where you live but some states in the US have laws against putting older engines in newer cars/trucks.
[/URL]
Old 05-04-2008, 12:54 AM   #6 (permalink)
Red
Red's Avatar
How compatible are Isuzu and Ford stuff? Cause the 3.2 turbo diesel out of a Rodeo tied to a 5spd would be a pretty sick 'stang
Old 05-04-2008, 11:03 AM   #7 (permalink)
Legend in my own mind
trikkonceptz's Avatar
Evil Pumpkin - '08 Scion xD RS 1.0 #1633
90 day: 35.45 mpg (US)
Silent Silver Killer - '10 Honda Insight EX
90 day: 51.5 mpg (US)
When you get right down to it, a custom conversion is just that custom. Unless there is a related engine or body that uses the same engine, forget about it, and just choose the engine and tranny set up you want for the vehicle. In order of difficulty;
-Fabricating solid engine mounts
-Making room in the transmission tunnel/ Fire wall, if need be
-Fabricating new tranmission mounts
-Having a custom drive shaft made to accept the tranny of one car and the rear end of another.
Hopefully you'll choose an engine with minimal electronics to make that part easy. So find yourself a good welder and a junk yard with lots of engines and happy hacking.
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
Old 05-05-2008, 09:15 AM   #8 (permalink)
Isuzu is tied to GM. Try a diesel Camaro.
Old 05-05-2008, 03:01 PM   #9 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
I would take a TDI jetta that had a beat up body and build your own mustang look alike body over it.
Other wise would a Ford truck engine fit?
Old 05-05-2008, 05:58 PM   #10 (permalink)
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
Maybe a VW diesel but otherwise it will be tough. Fords are very resistant to engine swaps because of their tight engine compartments.
Much easier to do engine swaps on GM vehicles.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
smart cdi (diesel) owner from BC, Canada smartzuuk Introductions 29 09-06-2018 03:09 PM
Mopar to offer Diesel Swap kit for Wranglers Red EcoModding Central 8 08-09-2011 06:23 PM
The Cars GM Needs To Make Big Dave General Efficiency Discussion 66 01-05-2009 03:18 PM
The Villian In The Diesel Fuel Price Disparity Big Dave General Efficiency Discussion 42 04-14-2008 08:10 AM
i-dtec (Honda Diesel) RH77 EcoModding Central 22 02-11-2008 01:20 PM
