01-02-2008, 03:04 PM
Lone Wolf Signs Up
Hi All -
I've been Ecomodding for years, working on my own without knowing what it was called. LOL. But here I am now, and I look forward to participating.
01-02-2008, 03:27 PM
ECO-Evolution
Welcome. Glad you found the site. What are you driving now and what have you done to it?
"Judge a person by their questions rather than their answers."
01-02-2008, 03:31 PM
Dartmouth 2010
Welcome to the site!
Same questions as laz apply,
01-02-2008, 04:56 PM
What I Have
Hi -
Thanks for the replies. I drive several vehicles: hot rod, antique, sports car, 4x4, and so on. The 4x4 (a Chevy truck) has enjoyed several mpg improvements over the years, but with modest changes that were mostly aimed at the reduction of parasitic losses and optimizing components for the predominant usage (which changes over time). I am now contemplating more aggressive changes, including better engine shut off and glide capabilities.
01-02-2008, 08:57 PM
Depends on the Day
Welcome
Welcome to EM
I have a couple more questions -- what kind of driving do you do mostly? ...and which vehicle are you using the most?
Sounds like a fun collection
Enjoy the site...
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
 _
 _
01-02-2008, 10:02 PM
Hi Plym49.
Looking forward to hearing about the mods you did to your Chevy in the past and what you've got planned for the future.
Welcome to the site.
01-03-2008, 11:45 AM
Good Morning, Glad to see another multi-vehicular modder. Didn't think about the lone wolf moniker myself. I get the impression there are many out there who are doing what they can without assistance from friends or family.
You're here now and these guys, who've been at it for way longer than me, will help all they can.
Again I say Greetings and Salutations. S.
When you are courting a nice girl an hour seems like a second. When you sit on a red-hot cinder a second seems like an hour. That's relativity.
Albert Einstein
01-03-2008, 02:47 PM
Responses to all
What do I drive most often: Well, I mix it up so everything gets used fairly regularly. Certain vehicles dont see rain or salt, though.
What type of driving do I do: A good mix of local, s&g commuting and superslab.
What mods have been done to my 4x4 truck:
Larger diameter tires inflated to 45 psi, replaced mechanical fan with variable-speed dual electrics, punched louvers in hood for better air flow (reduces need for fans when moving) and to vent high-pressure air under hood (hopefully reduced aero drag), custom chip, removed air pump (parasitic drag), low restriction intake and exhaust, custom ignition, higher temp thermostat, warm air induction, dual deep cycle batteries, hi-po gear reduction starter (to withstand frequent restarts when coasting), 0-30W synthetic, synthetic in diffs, probably some other stuff I forgot about.
Stock mileage was 14. With normal driving (no shutdowns, coasting or other special techniques) I see north of 17 for an almost 25% improvement. This is a 5000 lb vehicle with the aerodynamics of a brick. I would like to see over 20 for local driving where engine shutdown and coasting can be used. This might not be feasible without sacrificing the utility of the vehicle, but we'll see.
One of my previous projects was a 12 cylinder Jaguar XJ-S. These cars normally run in the 8 to 14 mpg range. Mine consistently delivered 23 mpg, with no special driving techniques and the stock TH400 automatic. However, there is a tremendous amount of low-hanging fruit - courtesy of odd design decisions by Jaguar - so my achievements here are not due to black magic as much as thoughtful modifications to implement features other automakers take for granted.
01-03-2008, 02:55 PM
#9 (permalink)
Here it is
Thumbnail of the 4x4 in question.
01-03-2008, 02:57 PM
#10 (permalink)
Here it is
Thumbnail of 4x4 in question.
