Old 03-19-2012, 12:04 AM   #1 (permalink)
Rookie Ecomodder
zoomzoom - '06 Mazda 6i sport
Lurker to lover
Hello,
Found this place searching for hypermiling or something. -Been lurking, but it seems I could not hold back and had to join to help and learn.
Since the price of gas has gone up (again) I started hypermiling -mostly coasting in my Mazda6 2.3 5 speed. My recent job commute has a lot of hills, so I took advantage of that and learned it has been two weeks without getting gas!
The car has been lowered, and I removed that gawd awful wing off the trunk and put on the factory duck tail. I could get up to low 30's on the highway, but want to improve that.
Since reading this site, I went after some more parasite drag: the moon roof deflector came off, and the front license plate was relocated lower, and unscrewed the top portion of the antenna -oh and I butchered the airbox to let more air in the restricted inlet. (it already had a K&N filter) -Sounds cool too !
Next may be a exhaust header and removing the back exhaust for weight loss and less restriction. Also thinking about moon discs for the rims once I find lighter rims. The front fog lamps jut out a bit and I want to do something with that too.
Once I figure out where to find that plastic card board stuff I want to tastefully do some experiments.
Looking forward to experiment and making progress!
Doug E.
Old 03-19-2012, 09:05 AM   #2 (permalink)
90 day: 51.82 mpg (US)
Got a fuel consumption display yet? That's the most important piece of the puzzle. It'll help you refine your driving and will allow you to evaluate mods to the car. Otherwise you're kind of flying blind.
Also: it's not clear that changing exhaust will improve fuel economy. More peak power? Sure. More MPG? Not necessarily. It could possibly hurt at low engine speeds (where we tend to cruise to save fuel). Search around here to see what people say about it.
Welcome to the site.
Old 03-19-2012, 10:47 PM   #3 (permalink)
larrybuck's Avatar
Location: sw Washington (state), a little north of Vancouver
Welcome!
Yes! Its a great feeling to start opening the wallet less often, and less wide.
Sounds like you are off to a great start.
Look up (google?) Coroplast to find in your area. Some on here have found it as close
as their nearest Home Depot.
06 Chev MonteC JG#24tribute car 30mpg 00 Honda Insight 63MPG 98 Buick Park Ave3.8 33MPG 89 Toyota Corolla wag 60MPG so far 07 Honda ST1300 55MPG 83 Honda 650 GL 64MPG 19 Suzuki dr200 88MPG23 HondaGrom?+Tow K10D Sub 26mpg NEVER,NEVER GIVE UP!
PUMP THOSE TIRES UP!
DRIVE IN YOUR SOCKS FOR SENSITIVITY!!!!!!!!!!!!!!!
SLOW DOWN AND SMOOTH UP!!!!!!!!!!!!!!!!!!!!!!!!!!!!![SIGPIC]
