Old 07-09-2022, 10:12 PM   #401 (permalink)
They look big, or is it a small couch?
Will you use any kind of edging? Underlapping or overlapping the fender?
"The Flat Earth Society has members all around the globe" -- The Flat Earth Society
Old 07-09-2022, 10:15 PM   #402 (permalink)
Phase's Avatar
Black Bullet - '19 Hyundai Ioniq Hybrid Blue
Same size as the cardboard ones I made. Just a small couch
I’ll probably put some weather foam strippings under Them along the edge line to prevent scratching the paint
The Following User Says Thank You to Phase For This Useful Post:
freebeard (07-09-2022)
Old 07-09-2022, 11:52 PM   #403 (permalink)
I'm about that far along with skirts for the Metro, cut from a Dish antenna. I'm thinking about a U- or J-shaped vinyl edge strip
Bulletproof latching system To Be Determined.
Old 07-09-2022, 11:59 PM   #404 (permalink)
Phase's Avatar
Dibond panels were only 30 dollars each from Home Depot. Paying 60 dollars to save one mile per gallon haha
freebeard (07-10-2022)
Old 07-10-2022, 10:05 AM   #405 (permalink)
Ecomodding Apprentice
Originally Posted by Phase View Post
I mean I could always use true carbon fiber. Just kidding. That stuff would be great but extremely expensive and would outweigh any gas savings.
Did you see my wheel cover picture?
If you do it right it's not so expensive, how much would manufacturer supplied wheel covers cost? $400 and painted for free?
I doubt with driving frequently at 80mph 8000 Al or grade 9 titanium would be more expensive. A 1M x 1M sheet of prepeg 2-300 GSM carbon is approximately u.s $80. It already has the resin infused so you just mold and bake it. Remember though something like glass fibre, aluminum or plywood well structured could do the same job and weigh the same/less.
Depends how much time you have. Spending 15 minutes a day extra driving at 10mph less may more than offset half tail modifications and make your car not stand out. If 15 minutes is worth more then modify but shop around, some unusual products like inconel are not so expensive anymore and might surprise you
Old 07-10-2022, 10:24 AM   #406 (permalink)
Maybe modding is just cool, irrespective of yield. You did good
Old 07-10-2022, 12:08 PM   #407 (permalink)
Phase's Avatar
I drive about 40-50k miles a year. Plenty of high speed highway trips. So the main goal of the mods is to save money on gas
Old 07-10-2022, 12:32 PM   #408 (permalink)
Wouldn't want that?
https://readytogosurvival.com › gray-man
41 Essential Rules to Become the Gray Man - Ready To Go Survival
The gray man doesn't seem any different from anyone else. Most of all, the gray man is good at hiding in plain sight. This makes you less of a target. People will be less likely to approach you for any reason. It also makes it easier to move through the crowd and get to where you want to go. And becoming a gray man isn't difficult.
Joggernot (07-10-2022)
Old 07-11-2022, 12:41 AM   #409 (permalink)
Phase's Avatar
Drilled into my car body! Ahhh
Got them bolted on. Did a few drive around tests. Will be tweaking angles and testing security next few days. Then will rivet the screw wholes and paint the covers factory black with shiny clear coat and used black bolts
So far so good. Clearance near the wheels is like half an inch. Seems a bit tight but working so far at low speeds. No idea how high speeds affect everything
ID:	32588   Click image for larger version
The Following 5 Users Say Thank You to Phase For This Useful Post:
aerohead (07-11-2022), Blacktree (07-26-2022), freebeard (07-11-2022), Joggernot (07-11-2022), Nathan jones (07-11-2022)
Old 07-11-2022, 09:06 AM   #410 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
Looks good.
IN my previous projects 10mm gap at rear have been enough clearance on fenderskirts. It will touch if any in tigth cornering. So Half a inch should be fine.
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
The Following User Says Thank You to Vekke For This Useful Post:
