Old 05-18-2013, 04:15 PM   #41 (permalink)
mikeyjd's Avatar
Matchbox - '93 Ford Festiva L
Team Ford
Last 3: 70.16 mpg (US)
Salamander - '99 Chrysler Concorde LXI
Team Dodge
90 day: 30.3 mpg (US)
Urquhart - '97 Toyota Tacoma 4x4 V6 3.4L DLX
Pickups
90 day: 25.81 mpg (US)
Smudge - '98 Toyota Tacoma
90 day: 40.65 mpg (US)
Calebro - '15 Renault Trafic 1.25 dci
90 day: 39.39 mpg (US)
Sure, replace perfectly good parts for no other reason than paranoia. Can't argue with that.
The parts are either good or they ain't.
but, but, but, they could eventually go bad...
Old 05-18-2013, 05:00 PM   #42 (permalink)
wdb
lurker's apprentice
PlainJane - '12 Toyota Tacoma Base 4WD Access Cab
90 day: 20.98 mpg (US)
Brakes get heat cycled. Mine have 91K miles of heat cycling. And it is not at all unusual for a rotor to fail catastrophically. So go ahead and call me paranoid. I'll call you an ambulance when your perfectly good brakes fail under an extreme circumstance.
Old 05-18-2013, 07:44 PM   #43 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
I'm not buying it. Pretty sure my '81 VW Rabbit had its original rotors and after 30 years they still worked fine. If you're not racing or driving in the mountains your brakes shouldn't get too hot. But hey, I'm not a mechanic.
Old 05-19-2013, 04:47 AM   #44 (permalink)
I wonder if that's going to happen before or after my Tempo does aero endos off the road because Hermie a.k.a. aeromodder says it has so much lift?
Actually I've never seen nor heard of catastrophic rotor failure, although I have seen warpage from a stuck caliper (motorcycle) and gouges from braking with brake pads that no longer had linings.
Old 05-19-2013, 07:17 AM   #45 (permalink)
90 day: 57.12 mpg (US)
It is not just catastrophic failure. I lost my '86 Rabbit when some jerk cut me off and slammed the brakes (for a R/R crossing light, but he did brake way early). Even though I started braking before he did, I slid into him anyway. ABS on a new car versus bad brakes and tires on an old one.
The damage was not that bad but the Rabbit was a real health hazard, offering no protection at all.
