Old 08-24-2013, 01:40 AM   #1 (permalink)
Ecomodest
Jasen's Avatar
The Van - '97 Chevy Astro AWD cargo van
90 day: 14.03 mpg (US)
Bumped my FE
My first tank trying to improve my FE got me a 1.2 mpg bump with no mods.
I know not great, but I'm learning the shift points of the auto trans, not going over the posted speed limit, trying to maintain a more content throttle position.
Just need the weather to cool down so I can roll the windows up.
Being a mad scientist is not as easy as it looks on TV
Old 08-24-2013, 01:46 AM   #2 (permalink)
cbaber's Avatar
Lean and Mean - '98 Honda Civic HX
90 day: 46.69 mpg (US)
From your last tank to this tank is a 1.2 MPG increase. It doesn't sound like much, but that's actually about 8% better! Your driving will continue to improve. What pressure are you running in the tires? A free/easy modification is to pump them up to sidewall max (or more if you dare).
1998 Honda Civic HX - My Project Thread
The Following User Says Thank You to cbaber For This Useful Post:
MetroMPG (08-26-2013)
Old 08-24-2013, 02:03 AM   #3 (permalink)
Ecomodest
Jasen's Avatar
Your right, I read the last tank as 14.4, it's 14.04
I keep the tires at the max 35psi. There only passenger tires and I haul a 1,500 lb load everyday. I'm not comfortable over inflating them in this situation for safety's sake.
I plan on getting some LT 3 ply sidewall tires in October, those I'll run up to 50-55 psi, they also have a bit better FE rating then my current tires, plus will offer a more stable and safe ride.
Old 08-26-2013, 12:56 PM   #4 (permalink)
90 day: 51.82 mpg (US)
cbaber is right: don't be discouraged by a 1.2 mpg difference! It's a significant amount of fuel & money saved when you're talking about something as thirsty as your van.
You would save $392 a year (20k mi., $3.61 gas) by going from 14.04 to 15.2 MPG (1.16 mpg difference).
fueleconomy.gov mpg/cost calculator: Save Money
If a Geo Metro driver made a 1.16 mpg improvement from a 50 mpg starting point, it would only save $33 a year for the same distance/gas cost.
(There's the problem with talking in "MPG" in a nutshell. But that's another topic.)
Keep going!
Old 08-26-2013, 05:42 PM   #5 (permalink)
jedi_sol's Avatar
2013 STi *SOLD* - '13 Subaru Impreza WRX STi
Subaru
Sports Cars
Team Turbocharged!
90 day: 26.59 mpg (US)
1996 Geo Metro *RETIRED from Ecomodding* - '96 Geo Metro Base
90 day: 58.68 mpg (US)
Dont fret...its all the little things that add up in the end. A lot of the mods we do here only net us 1-3 mpg at a time. However, if you "stack them...3mpg, 2mpg, 3mpg...1mpg...1 mpg"...before you know it, you have a 10mpg increase over EPA.
See the rest of the Sti project log:
http://ecomodder.com/forum/showthrea...log-26612.html
Old 08-26-2013, 06:34 PM   #6 (permalink)
Hydrogen > EV
Silver Flea - '05 Honda Insight
90 day: 58.96 mpg (US)
Of course everyone else makes very valid points, going for the long haul will make a difference. I think about my antenna delete, and I would probably need serious equipment to calculate the difference, but over the years of owning it, I am sure it will pay the ~$3.00 it took to make it.
Every little bit adds up!
Best Tanks:
Mustang - 54.83 mpg (US) at the Green Grand Prix
Insight - 82.91966 mpg (US) over 818.5 miles.
Old 08-26-2013, 07:23 PM   #7 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 49.47 mpg (US)
Better than you think
Don't feel bad, man - you're exceeding the EPA estimate with 1500 lbs aboard all the time? You're doing well.
Old 08-26-2013, 08:28 PM   #8 (permalink)
Ecomodest
Jasen's Avatar
thanx gang.
I'm still learning to drive my van, I've only had it for 9 years
Driving my shift points is starting to feel natural, don't hardly watch the speedo now, can just feel it's time make it up shift.
Old 08-28-2013, 11:50 PM   #9 (permalink)
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Originally Posted by Jasen View Post
thanx gang.
Keep up the good work!!!
As others have already said every little bit makes a difference.
Pressure Gradient Force
The Positive Side of the Number Line
Old 09-05-2013, 12:31 PM   #10 (permalink)
Before you know it, you'll be having to stop and drain gas out of your tank ever 100 miles or so ;-)............
