Old 02-22-2018, 07:42 PM   #121 (permalink)
90 day: 51.82 mpg (US)
You know spring is just around the corner...
... when you're pricing a water pump & timing belt kit for your summer turd-mobile.
The pump started leaking pretty spectacularly the week I put it away.
Crap! I just realized I have both a winter beater and a summer beater. That's not how that's supposed to work.
Old 02-22-2018, 09:21 PM   #122 (permalink)
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
Originally Posted by Titanium View Post
Yes, that helps since I always considered buying a Miata to daily drive.
I'll post an update once I get my 3.63 rear end installed and my car tuned for lean cruise on the highway. I'm expecting high 30's (provided I can stay out of boost lol) but we will see.
Old 05-02-2018, 09:29 PM   #123 (permalink)
first 2018 start
First engine start of the year happened this week -- and it fired right up!
(I needed to move the car .... and couldn't just push it where it needed to go. I tried!)
I'm not planning to put the car on the road any time soon. Will do the water pump in June or July.
Old 05-15-2018, 09:41 PM   #124 (permalink)
tonneau!
I saw my Miata-owning buddy this evening, first time this year. His car is out of storage and the top was down.
He's got a factory tonneau cover for me that he never uses. (I may have posted about this before?)
It's gotta help aero a tiny bit. I'll tuft test it of course to see if there's any attached flow.
freebeard (05-15-2018)
Old 05-16-2018, 12:13 AM   #125 (permalink)
Smokey - '13 Chevrolet Cruze Eco
If the tonneau cover is not solid, maybe you can raise the center behind the seat for a downward slope?
Old 05-16-2018, 11:07 AM   #126 (permalink)
It's not solid -- vinyl with clips etc. But it's a fairly tight fit when in place, going by memory of my aunt's Miata from back in the day.
I'll see what the wind looks like and go from there.
I predict it's generally going to be a turbulent hot mess. Possibly some organized flow on the outsides. We shall see. (I'm not actually planning to press the car into service for a couple more months.)
Old 05-16-2018, 12:01 PM   #127 (permalink)
I did some crude test the other day. I raised my hand all around to see where the air turbulence is and is not. I was surprised how high and far back I could reach before I hit the passing air flow. The sides came in near the seats. I have a 2003.
The Following User Says Thank You to Grinder74 For This Useful Post:
MetroMPG (05-16-2018)
Old 05-16-2018, 12:40 PM   #128 (permalink)
Ooh, good tidbit. That's what I figured.
You should make a garage entry for yours so we see it under your username/info:
Your Garage
: [ Add new vehicle
Old 08-15-2018, 01:57 PM   #129 (permalink)
Hibernation exit ... mold!!
I pulled the car out of (indoor) storage last night, and holy crap! A lot of the interior plastic/vinyl surfaces had mold growing on them!
The steering wheel in particular was super gross -- a fine green fuzz all over it. I wore work gloves to move it.
The last time I'd checked on the car was in May, and it was fine. I'm not sure what happened since then.
This is a car I was planning to neglect in terms of cleanliness (reformed car neat freak here!), but I just spent 45 minutes wiping down every inside surface with a bleach/water solution. Still need to vac/shampoo the seats. This is NOT how I want to be spending my time!
Ecky (08-15-2018)
Old 08-15-2018, 02:12 PM   #130 (permalink)
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
Windows up the whole time?
