Old 08-15-2018, 02:19 PM   #131 (permalink)
90 day: 51.82 mpg (US)
Yup, windows up. Mistake? I've stored other cars windows up with no problems.
It was parked in an unheated garage with a concrete floor that is closed up for weeks (months) at a time. Though since May we've seen some record heat & humidity around here. (One reason why I've been in no hurry to get the Miata out of storage!)
Now I'm scared to go look inside the Firefly vert... I haven't been inside that car for a couple of years!
Old 08-15-2018, 11:40 PM   #132 (permalink)
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
Just thinking the lack of air flow would encourage mold growth. Rest of garage is OK?
Old 08-16-2018, 11:00 AM   #133 (permalink)
Yeah, no obvious crazy mold anywhere else. I'll check the Firefly vert in the next couple of days.
Old 08-16-2018, 04:31 PM   #134 (permalink)
Next up: first aid
Man, this is not going to be a small job...
There was a small leak late last fall. I just nursed it along, topping up with water as needed. Not any more! Pour water into the radiator, and it pours right back out the pump (see garage floor, above).
I swear the last water pump I replaced took half an hour, tops. (MK1 Rabbit/Golf? I forget.) This one's buried - going to take a while.
Old 08-16-2018, 04:32 PM   #135 (permalink)
Mold is a picky eater?
Old 08-16-2018, 04:41 PM   #136 (permalink)
That's what I don't get: what the heck was so tasty to eat in the car?
Is it because I never really cleaned it? It's a convertible -- lots of organic material/dust inside?
Old 08-16-2018, 10:33 PM   #137 (permalink)
I suspect it is the plastic itself.
Old 08-17-2018, 08:19 PM   #138 (permalink)
Didn't one of the manufacturers recently admit that some of their wiring harnesses were accidentally made particularly tasty to mice/rats?
Old 08-17-2018, 08:32 PM   #139 (permalink)
Miata drum brake conversion!!
Holding water!
So, I got the water pump in. (Man, that was a stupidly big job.) Radiator is topped up, test started, and nothing's leaking. Haven't got it up to operating temp yet, but I'm sure it'll be fine.
But what about brake drag!?
With the size of the aftermarket for these cars, surely someone sells a low-drag Miata disc-to-drum conversion kit, right? Surely?
I told myself I wasn't going to do any more mods to the MPGiata this summer due to chronic TMFP (Too Many Projects!!).
But I've always hated how much harder this car is to push around the driveway than the Firefly/Metro, considering they're within a hundred pounds of each other. And it just doesn't seem to coast well at low speed.
I could even hear that telltale quiet "grumble" of the pads dragging on the rotors when rolling at very low speed.
So I caved in and pulled the slider pins out of one of the front calipers this evening, and one of the pair absolutely did NOT deserve the name of "slider". So sticky! Nearly seized, really. Anyway, it's all cleaned up and everything floats/moves much better. Only 3 more calipers to go!
Also I noticed there were no springs in there, like this Miata (D):
Details: http://dirtyshirt.info/auto_mazda_miata_brakejob.html
Need to get me some of that!
Old 08-17-2018, 10:45 PM   #140 (permalink)
IGL - '04 Saturn Ion
Team Saturn
90 day: 56.19 mpg (US)
You’re averaging 50mpg with the MPGiata and haven’t got brake return springs? Don’t feel bad, I haven’t got any either lol
My current Ecotec project...
My last Ecotec project...
