Old 06-20-2008, 05:39 PM   #1 (permalink)
SeeOurWrecks - '91 Honda CRX Si
90 day: 35.59 mpg (US)
Accord_Inspire - '93 Honda Accord EX
90 day: 24.56 mpg (US)
Got it in car, having trouble
Hey all, new member, first post.
I got my mpguino assembled and running, and today I got it wired into the car, but it's not working. It stays at zero like it would with no input.
I'm wondering if the resistance inline is too high.
With the key on, and engine off (KOEO) the vss sends .17v
KOEO injector 1 sends 11.32 volts
With the Key on engine running (KOER) the injector fluctuates between 13.5 and 13.65 volts
The VSS still sends .17 because its not moving
Now where those leads meet the circuit board the readings are lower of course
KOEO vss provides 0.0 volts, sometimes barely giving 0.1
KOEO inj provides .56 v
KOER vss gives .01 volts and inj gives .56-.57v
This is installed in a 93 honda accord ex, I did some rudimentary math and changed my code to
vss - 4104
966488100 microsec/gallon
tanksize 17000
using v0.63
The numbers I will change when I get some readings but I can't get that far yet. Any suggestions?
Old 06-20-2008, 06:33 PM   #2 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
take a look at the "Instant Raw Data screen" whilst toodling around, uS should be proportional to injector duty cycle, IC should be porportional to RPM, and VC should be porportional to the vehicle speed.
If none of those show anything then describe where you tapped the injector and the vss? What color is the vss wire and what color is the injector wire?
Old 06-20-2008, 06:43 PM   #3 (permalink)
all screens show nothing but zeroes, as if I never hooked them up
vss I tapped into pin b10 by the ecu, injector 1 I used a brown wire with I think red dots, pin A1. I plotted these pins using my helms repair manual. I'm almost 100% certain I'm using the correct pins, BUT I should be using the positive leads for both of these, correct?
As an aside, the power plug the guino comes with doesn't seem to do squat, I have to wire up to VIN and GROUND, on the board for it to work, does that sound right? I wired both at the same time, just to be sure
I'm using rj45 ports and a length of cat5 to run the signal from the ecu area to the guino
I'm off to work, I'll be back later tonight
Old 06-20-2008, 07:04 PM   #4 (permalink)
Whoop's Wheels - '89 Honda Civic Wagovan
90 day: 39.09 mpg (US)
I don't know about the VSS, but on the injector, it runs off of what you might call negative logic. The power to the injector is supplied whenever the fuel relay turns on. The ecu provides a signal which grounds the other side of the injector when it turns the relay on.
Old 06-20-2008, 07:27 PM   #5 (permalink)
dcb
needs more cowbell
dcb's Avatar
For VSS, if you can find a picture of the ECU plug online I might be able to point out the speed signal, my cryptic docs indicate it should be Pin 8 on a 24 pin connector, maybe yellow/white, or orange, or yellow/blue?
For the injector, you unplug an injector and turn on the ignition (not the engine) and use the injector wire that DOESN'T have 12 volts on it.
Old 06-20-2008, 10:56 PM   #6 (permalink)
So should I be running a ground? what completes the circuit, ground to ground? I'm not proficient in electronics, I have an amateur knowledge.
VSS, it was a bright orange wire
injector, to test my manual says use a1 for injector 1 and a23 for ground. But using a23 would not give off a signal just a ground? Am I wrong?
It does say to measure for battery voltage so it is the one putting out "12v"
I do use an injector resistor in this car if that makes a difference
This pic is for an integra but it should be exactly the same as the OBD1 accords
can't find a pinout, but I'll keep looking
*EDIT*found one
http://www.superhonda.com/forum/f55/...inouts-217405/
Old 06-20-2008, 11:25 PM   #7 (permalink)
Don't know if this helps
Old 06-20-2008, 11:45 PM   #8 (permalink)
dcb
needs more cowbell
dcb's Avatar
Are you using B10 for the vss?
http://www.innovatemotorsports.com/r...nda_Accord.php
Old 06-20-2008, 11:52 PM   #9 (permalink)
yup
Old 06-20-2008, 11:56 PM   #10 (permalink)
dcb
needs more cowbell
dcb's Avatar
Can you rig up some alligator clips or test leads and and watch the voltage on b10 as the car rolls slowly?
P.S. the ECU will ground out the other side of the injector, you want to be tapped into the injector line that leads to the ECU, not the one that leads to the resistor.
I found another advantage to driving an ultra-low Cd car basjoos Aerodynamics 26 08-25-2012 02:15 PM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 55 08-20-2012 11:34 PM
Win $100.00 in Free Gas! Design Contest: Ecomod my Ride XFi EcoModding Central 127 02-17-2011 12:07 AM
My First Electric car Experience WaxyChicken The Lounge 8 09-05-2008 08:46 PM
$500 and 30mpg car? possible? olderthanme EcoModding Central 6 07-15-2008 09:37 PM
