Old 08-31-2008, 12:16 PM   #1 (permalink)
90 day: 51.82 mpg (US)
MPGuino installation/setup: 1998 Geo Metro (Pontiac Firefly)
dcb recently sent me a "care package" with a couple of components my small town rat shack didn't have. To my surprise there was also an "evaluation" MPGuino in the box!
I hooked up to the car (1998 Pontiac Firefly 1.0L TBI 5-speed) this weekend.
Random observations:
1) COOL!!!
2) finding the injector & VSS wires was easy, mostly because dcb has the same car as mine and has blazed that path already (with pictures!): http://ecomodder.com/forum/showthrea...html#post30667
3) with those settings, the MPGuino was showing half the MPH that the speedometer/ScanGauge showed, so I halved the VSS Pulses/Mile value in the MPGuino setup (to 8204), and that seemed to fix it.
4) I still need to factor in an additional offset for VSS Pulses/Mile, because the transaxle I swapped into my car (with a taller final drive ratio) was originally calibrated with a smaller tire size (diameter) than my tires.
5) The car's MPH display is jumpy, as dcb already noted with his Metro, though he also found that despite this, the total distance traveled seems accurate.
I was thinking I could calibrate my car's VSS pulses/mile setting by jacking up the drive wheels and idling the car in 5th gear to rack up some mileage without having to drive around unnecessarily. It seems to idle @ about 30 mph.
Any technical reason I shouldn't do this? (Aside from the fact it'll pad my tank MPG with some awesome numbers - seems to get about 150 mpg idling in 5th on jack stands. )
I probably won't have a chance to calibrate the MicroSec/Gallon until I get back from the tall ship race though, because I'll have to do some actual driving to tweak it.
Old 08-31-2008, 12:23 PM   #2 (permalink)
VIVA LA MPG RESISTANCE
Will's Avatar
Meat-roll - '97 Geo Metro
90 day: 55.4 mpg (US)
Wife's Brruik - '03 Buick Century
90 day: 30.84 mpg (US)
Blue Balt - '08 Chevrolet Cobalt XFE
Team Chevy
90 day: 38.19 mpg (US)
I think it would be ok, and really neat to see. Just be real careful!!!!
IMO I would ask Johnny what he thinks...
Old 08-31-2008, 09:31 PM   #3 (permalink)
Addicted
bbjsw10's Avatar
bbjsw10 - '91 Geo Metro Xfi
90 day: 51.06 mpg (US)
You are running the Xfi transmission correct? So the vss pulses should be the same for mine right? Ordered my stuff today to make my MpGuino Iduino, can't wait real feedback finally.
And can you enter these numbers right through the MpGuino setup screen?
Old 08-31-2008, 09:49 PM   #4 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
Nothing wrong with having the car securely raised and supported while you run it in gear at idle. This will make the axles have slightly more flex than usual, but it should be fine for a short period of time.
GeoMetroforum.com - got mpg?
Old 08-31-2008, 11:32 PM   #5 (permalink)
bbjsw10: I'm running the Swift 1.3 SOHC transmission, not the XFi.
Mullet: thanks for that. I will admit I suspected as much and went out and ran the "jack stands calibration run" before I read your reply. Stuck a snow scraper lightly against the gas pedal and accumulated 20 miles per the ScanGauge. That'll give me enough info to get the Guino dialed in (when I get back from my trip).
Old 09-01-2008, 12:52 AM   #6 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
Cool, let me make a guess at your modified vss pulses per mile (stock *should* be 8208). Assuming your tire circumference is 5% greater than stock for that tranny, I will guess you have an effective vss pulses per mile of 7798.
Also will stash the metro install pics here till we get car specific wiki pages with setup data AND pics:
Old 09-01-2008, 08:10 AM   #7 (permalink)
metroschultz's Avatar
CPT SLO - '93 GEO Metro plainjane
90 day: 53.91 mpg (US)
SilverHairBeauty - '01 Toyota Avalon XL
90 day: 24.06 mpg (US)
Send a message via AIM to metroschultz
Just a note
The injector drive wire comes from the ecm as well.
You wouldn't need to run any wires to the engine if you tap all of them onto the ecm.
S.
When you are courting a nice girl an hour seems like a second. When you sit on a red-hot cinder a second seems like an hour. That's relativity.
Albert Einstein
Old 09-01-2008, 09:13 AM   #8 (permalink)
dcb
needs more cowbell
dcb's Avatar
I've had mixed results tapping into the ECM for the fuel injector, would like to see someone actually make it work before calling that a certainty.
Old 09-02-2008, 07:48 AM   #9 (permalink)
4OVER4 - '85 Mitsubishi Starion ESi
90 day: 24.97 mpg (US)
Auto - '87 Mitsubishi Starion LE
90 day: 23.65 mpg (US)
Soarer - '96 Lexus SC-300
90 day: 25.27 mpg (US)
Worked for me - got Injector and VSS from the ECU...
Old 09-15-2008, 07:01 PM   #10 (permalink)
How I collected my speed/distance calibration info for the Guino...
racprops (10-11-2009)
Need Geo Metro information.. Chris D. Off-Topic Tech 5 01-23-2013 05:28 PM
Final gear drives for GEO METRO, Swift...Firefly Frederick For Sale 7 09-09-2009 12:03 AM
1990 Geo Metro Idle test cinaroh EcoModding Central 2 07-08-2008 10:15 PM
1995 Geo Metro DRL disengage tip akcapeco EcoModding Central 1 06-10-2008 10:07 PM
CL: Mechanics Special 94 Geo Metro Red For Sale 4 04-09-2008 01:48 PM
