Old 03-14-2019, 08:52 PM   #11 (permalink)
I've never seen a vehicle *not* produce tremendous amount of if black smoke when seafoam is fed into one of the lines, FWIW.
Yes but it was coming from the exhaust manifold
Old 03-14-2019, 09:09 PM   #12 (permalink)
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
I hope I'm not being dense, but where else would it be coming from?
Old 03-15-2019, 12:59 AM   #13 (permalink)
Well normally it comes from the tailpipe but since it's coming from the exhaust manifold that means its cracked/leaking and needs to be replaced/repaired
The Following User Says Thank You to crz650 For This Useful Post:
Ecky (03-15-2019)
Old 03-15-2019, 08:42 AM   #14 (permalink)
Move to Texas. Much cheaper to own a car, and we are not anal about it!
Old 03-15-2019, 09:05 AM   #15 (permalink)
90 day: 57.12 mpg (US)
You seem to doubt the cat, judging by the question mark.
Instead of buying new while not knowing if it even cures the problem you may try this:
https://ecomodder.com/forum/showthre...hod-35264.html
Old 03-15-2019, 10:55 AM   #16 (permalink)
It has been 20 years since I moved, but isn't there a process where you can get a 1 year one time exemption?
You can braze the manifold cracks for a short term repair. I haven't had a lot of success with welding but the brazing I did lasted many years. I have also used 3 gaskets and longer bolts, and a roll of exhaust fix it tape.
You didn't indicate whether or not you did anything major to repair before secondary smogging.
Old 03-15-2019, 11:26 AM   #17 (permalink)
suzi - '93 Suzuki Sidekick glx
recycler - '93 Honda civic ex-s
Toyota - '09 Toy Matrix base
gigi - '04 Honda Element EX
CA won't allow tape on intake manifold (or exhaust) but brazing is allowed. You cant weld cast iron I was told by a experienced welder (on a Suzuki sidekick). I couldn't source an exhaust manifold any of my sources. Some of the newer expoxies would probably work. The crack is no doubt making a lean(irregular) reading at O2. No smog here in southern OR. You pay in smoke when you get behind the logging trucks(injection pumps are turned advanced. I guess carb legal header is big bucks (maybe a used one.. I have everything but e/manifold and ecu for vx. I would check jdm engine
importers and Picknpulls.
Old 03-15-2019, 11:34 AM   #18 (permalink)
Master Ecomadman
arcosine's Avatar
sc1 - '98 saturn sc1
Team Saturn
90 day: 43.17 mpg (US)
rans - '97 rans tailwind
90 day: 28.25 mpg (US)
red bug - '00 VW beetle TDI
big tractor - '66 ford 3400
90 day: 58.42 mpg (US)
RV - '88 Winnebago LeSharo
90 day: 16.67 mpg (US)
Change your oil. My saturn failed and I changed the oil and it passed. Lots of HC in old oil.
Use a nickle electrode to weld cast iron. Epoxy wont work.
https://www.google.com/url?sa=t&rct=...UJtT2hCDMnV_08
- Tony
The Following User Says Thank You to arcosine For This Useful Post:
whaemmel (03-15-2019)
civic, civicvx, mods, smog
