Old 08-23-2013, 09:37 PM   #71 (permalink)
If you set the back down too far you'll be catching air all underneath.
When GM ran an S-10 at Bonneville (back when they were selling the Syclone) they found the best drag reduction from having the rear 2/3 of the bed covered, with a solid wall from the front of the cover down to the bottom of the bed. Of course the whole truck was lowered too.
Old 08-25-2013, 09:51 AM   #72 (permalink)
radioranger
Well I was thinking cost benefit ratio, the front end on an i beam truck is prety pricey to lower, the rear pretty cheap, and could also throw a lower air dam on it the same time, wonder if anybody tried it, seems liike it could offer good results since the roof angle and windsheild angle would be better.
Old 08-26-2013, 05:40 PM   #73 (permalink)
nathan01xl's Avatar
The Long Ranger - '01 Ford Ranger XL
Pickups
90 day: 28.68 mpg (US)
EcoSI - '08 Honda Civic SI
90 day: 28.83 mpg (US)
i don't think dropping the back significantly would do any good for mpgs. if you think about the design of an aero cap, the ideal slope actually crosses over the top of the tailgate not below it. with this in mind i cant imagine any aero benefit from just a slammed rear end.
Old 08-26-2013, 08:13 PM   #74 (permalink)
radioranger
Could be your right but I was thinking about the windshield angle also as well as the roof of the cab starting down earlier,
Old 08-28-2013, 07:08 PM   #75 (permalink)
Originally Posted by nathan01xl View Post
good to know, i am definitely going to keep my eyes open for a 3.45 rear end or set of gears. might have to go through a few JYs and see if i have any luck.
I have a Ranger axle geared 3.42 just sitting in my garage looking for a new home! It is from my '92 so it is about 2in narrower than yours, perfect if you are doing wheel well covers.
OIF Vet
'03 Ford Ranger 4X4 lifted, 4.0L, 33in tires, plywood tonneau = 18MPG Best Tank
'92 Ford Ranger 2wd stock 3.0L with at least 189,000 miles! = 23MPG Best Tank
'99 Ford Ranger 4x4, stock 3.0L SOLD............................. = 25MPG Best Tank
Old 08-28-2013, 08:14 PM   #76 (permalink)
nathan01xl's Avatar
Pickups
perfect if you weren't all the way in minnesota lol
Old 08-28-2013, 09:05 PM   #77 (permalink)
I don't know where pdx is so I figured I would at least offer it up. It's not doing me any good and if I scrap it it is only worth like $10. Worth a try, right?
OIF Vet
Old 09-02-2013, 05:50 PM   #78 (permalink)
nathan01xl's Avatar
Pickups
Did engine maintenance this weekend, cleaned throttle body, IAC, and changed oil to Mobil 1 0w-20 (6k since last change with synth blend). Will be cleaning the MAF sensor once I get some torx security bits from Amazon thursday, seriously WTF Ford why can't you use normal bits?!
Cardboard upper grill block is falling apart due to recent rain showers, have some plans in mind for the replacement but need to get some coroplast or something similar to do so. Probably will remake my sideskirts with coroplast as well if I can score a 4x8 sheet from the sign shop in town.
Old 09-02-2013, 08:34 PM   #79 (permalink)
90 day: 51.82 mpg (US)
Neither did I... GOogle to the rescue!
PDX - Wikipedia, the free encyclopedia
Old 09-02-2013, 11:21 PM   #80 (permalink)
nathan01xl's Avatar
Pickups
WOOHOO Portland, Oregon!
