Old 05-29-2010, 03:06 AM   #11 (permalink)
I think the lycra is a lot better idea than what people usually use. Not only is it easy to cut and fit, but it might let air through once the fans start sucking
Old 05-29-2010, 09:38 AM   #12 (permalink)
Gen II Prianista
Rokeby's Avatar
The custom audio crowd does a lot of one-off speaker enclosures using
fabric and probably polyester resin.
Watching a typical video can be instructive. Here's an example:
(Warning; Turn down your volume.)
If you poke around the web using search terms along the lines of "diy
car speaker enclosure" you may find something more descriptive.
Hope this helps.
It's been darn cold here... (cai delete + grille block) wdb EcoModding Central 17 02-25-2010 11:18 AM
Chevy AVEO: Adding grille blocks and air deflectors Thymeclock Aerodynamics 11 01-02-2010 04:39 PM
Partial grille block - Fully duct tape jesse.rizzo Aerodynamics 12 02-18-2009 05:12 PM
Grille block: front or back and top or bottom? 07b2300 Aerodynamics 11 07-07-2008 10:19 PM
Full Grille Block: Upper Grille DifferentPointofView Aerodynamics 12 02-28-2008 10:14 AM
