Old 11-04-2009, 09:59 PM   #21 (permalink)
3-Wheeler's Avatar
AlienMobile - '00 Honda Insight
90 day: 80.05 mpg (US)
Nice job!! Wouldn't mind some more pics when you get to it.
I use a Fumoto drain valve for the oil drain, and provide a small hole in the fiberglass panel for access. As for oil filter access, I have a small 6 x 8 inch opening that is used, and can be seen here...
http://ecomodder.com/forum/showthrea...els-10638.html
I noticed that the exhaust pipe on the Honda Insight does not run as hot as first suspected during panel construction. The foam softens noticeably at 250F as tested in the oven with temp probe, and there are no signs of overheating next to the pipe on the car. Aerocivic has had no problems either.
Jim.
Chrysler Expected To Kill Models, Bring Italian Vehicles Ashore Jammer The Lounge 17 06-26-2010 07:29 PM
Underbelly clean up Phase II EXPIOWA Aerodynamics 3 04-29-2009 01:23 PM
Underbelly smoothing options Sunwapta Aerodynamics 17 11-08-2008 01:41 PM
2007 Dodge Caliber: The Drive DifferentPointofView EcoModding Central 0 06-19-2008 07:58 PM
Dodge ZEO BEV sports car cfg83 General Efficiency Discussion 0 01-16-2008 10:55 PM
