Old 08-28-2014, 12:30 AM   #1 (permalink)
herp derp Apprentice
Saturn-sold - '99 saturn sc1
Team Saturn
90 day: 28.28 mpg (US)
Yukon - '03 GMC Yukon Denali
90 day: 13.74 mpg (US)
my wheel skirt fail. basic design issues? testing? other ideas?
i was planning to make a set of wheel skirts, they seem like they work for most everyone else. attachment i had in mind would be hard to do an a-b-a on, so i figured i would just slap on a cardboard set to test. i made 9 east and west runs, 3 sets w/o skirts, 3 w/skirts, and 3 more w/o. i know my mileage seems to magically keep creeping up from previous testing.
measured w/ scangauge2
runs 1-3 avg 42.78 w/o skirts
runs 4-6 avg 42.92 with skirts
runs 7-9 avg 43.77 w/o skirts
so it looks like the skirts lost me 0.8% (the west run on #9 was an outlier on the high side but after trying to control for that the skirts still lost me 0.2%)
the skirts are about as long / low as i thought i could run with a flat panel. they get within about 1/2 inch of the tire at the bottom edge. while i didnt think that these would do as well as a longer skirt, i was virtually certain they should have had a positive affect. ...my best idea so far is just to retest, other thoughts?
the test skirts
old pic w/o
Old 08-28-2014, 12:37 AM   #2 (permalink)
Maybe that is all they are worth.
I had skirts on the Coupe and couldn't detect any fe change, better or worse (no instrumentation- tank-to-tank).
Old 08-28-2014, 01:55 AM   #3 (permalink)
If the mileage is creeping up steadily, then you have to figure out why and get the car stable enough to have consistent results. Could be the car running in on the oil... or temperatures becoming more ideal as the day gets warmer/cooler or as air pressure changes.
How do runs 3 and 4 compare? How do runs 6 and 7 compare?
Old 08-28-2014, 03:08 AM   #4 (permalink)
Team Saturn
1 43.25
2 43.4
3 41.7
4 42.7
5 42.75
6 43.3
7 43.75
8 43.15
9 44.4
The individual east west runs have even greater variations, it is surprising how when all the runs without the skirts are averaged out, how close it is to the average of the runs with skirts. Which i guess is why I used 9 runs instead of 3.
I think the mileage keeps going up with trans, engine oil, tire temps, and maybe increased rake as the fuel tank gets lighter. I had thought before that it stabilized after about half an hr, but had since found it only slowed, and haven't found the point where it stops going up. I chose a test area on the far side of town to help warm things up, and I'm guessing by the end of the last run I put over 80 miles on the car since I left home, and the mileage still climbing.
The car burns oil at about a qt/1500mi which I wouldn't think would have any significant affect. Temps/ weather were basically stable throughout the test, which I don't really think was a factor as I would have been more surprised to not see this happening again.
Anyone have other examples of longer tests showing mileage creep, or totally stable for that matter?
Old 08-28-2014, 04:52 AM   #5 (permalink)
cowmeat's Avatar
Princess Carriage - '20 Ford Explorer Limited
Silver - '22 Ford Maverick Hybrid XLT w/tow pkg
Maverick Hybrids
90 day: 41.3 mpg (US)
You can make them lower, bro! They probably don't cover enough real estate to do much as-is. Black Widow's are fully horizontal, and they come within a half inch of the rear tires. The trick is to flare them out ever so slightly at the bottom, which is accomplished when you attach the front and rear lowest screws/clips.
I would test them for a full tank, that'll give you a better idea if they are going to be worth permanently installing. If you're questioning your instant read-outs, there's nothing like a full tank's mpgs to average all the conditions out.
I don't have any instrumentation, but in all honesty mine really don't make much of a difference, maybe because my wheel wells are smaller than the average car's. They definitely get people talking about the car, though! My installation is on here somewhere if you want to see how to NOT do it, lol!
Old 08-28-2014, 06:41 AM   #6 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
If SG testing isn't conclusive, it's time to move to coast down tests.
Old 08-28-2014, 12:15 PM   #7 (permalink)
90 day: 51.82 mpg (US)
I'm with Frank: it's possible the benefit is so small as to disappear in the normal static/variability of testing.
Old 08-28-2014, 12:19 PM   #8 (permalink)
Not bad for a machine
dirtydave's Avatar
Maechunbu - Retired - '00 Kia Sephia 1.8I4 16VDOHC
Last 3: 45.28 mpg (US)
Slasher - '96 Chevy Corsica 2.2L 3speedauto
Duct Tape Aero Crew
Team Chevy
90 day: 34.76 mpg (US)
Well I don't think it can hurt!
Old 08-28-2014, 12:33 PM   #9 (permalink)
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
Don't give up. If you never fail, you aren't trying hard enough.
The car does look to have rather tight wheel wells. Maybe partial shirting to fill in the gaps (plus Moon eyes) would be the optimum.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
Old 08-28-2014, 04:15 PM   #10 (permalink)
90 day: 57.12 mpg (US)
The skirts need to be really stiff to work right.
The cardboard does not look very rigid, esp. those 2 vertical folds. If it deforms or vibrates that will reduce its effect big time.
Cardboard is usually much stiffer in one direction than the other.
The central layer forms a wave shape between the outer layers, creating channels in between. It bends easily parallel to those channels, not so across them.
I suspect you used it in vertical orientation (the folds seem smooth, like they'd be when folded parallel with the channels)
If you do a rerun with horizontally oriented cardboard skirts that may show better results. Make it a double layer just to be sure.
Even if it works I'd expect a reduction in fuel consumption of about 1 - 1.5 %.
It will be hard to prove it does make a difference.
niky (08-28-2014)
