Old 11-01-2011, 07:27 AM   #31 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 144.39 mpg (US)
Send a message via MSN to jakobnev
I don't think you should be expecting it to make economic sense to "own" you very own pump. But maybe if you shared it with 10, 20, 50, or even 100 others, the numbers would be on your side.
With 20 users the installation would be only $90 a pop and the monthly fee is $2.30.
Old 11-01-2011, 08:28 AM   #32 (permalink)
CFECO
CFECO's Avatar
X-Car - '11 Homemade 2+2
Velbly1 - '17 Toyota Camery XSE
90 day: 29 mpg (US)
Velbly2 - '13 Toyota Tundra
90 day: 18.03 mpg (US)
Google "Impco", and you'll find all you need to convert a gas engine.
Old 11-01-2011, 08:35 AM   #33 (permalink)
What is the range of a typical CNG car? Where can you fill the tank?
Old 11-01-2011, 02:26 PM   #34 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
As with petrol, it varies .
150 - 300 miles.
360 miles is the max for OEM cars AFAIK, VW Caddy Maxi Ecofuel
At preciously few locations in most countries.
Though (in EU) Italy, Germany are leading the way.
I've seen quite a few CNG pump in Sweden as well.
Old 11-01-2011, 03:19 PM   #35 (permalink)
The PRC.
CNG cars are usually dual fuel here in the UK, so the range is as far as the next petrol station will carry you An advantage is you also save on tax as a CNG car can be re-registered as an "Alternative Fuel" vehicle, which usually means £0 tax and no charge in the London congestion zone.
It takes 9-18000 miles of CNG motoring to pay the cost of the conversion though.
Old 11-01-2011, 03:32 PM   #36 (permalink)
L/100km
Missy - '06 Scion xA
90 day: 35.62 mpg (US)
Hi Arragonis,
Is it not mostly LPG in the UK?
Old 11-01-2011, 04:43 PM   #37 (permalink)
CFECO
CFECO's Avatar
90 day: 29 mpg (US)
When running CNG or LPG the engine can be modified with a higher compression ratio or turbocharging ( watch out for high exhaust temps though), thereby making more HP, so a smaller engine may be possible, with a mpg increase.
Old 11-02-2011, 05:36 AM   #38 (permalink)
The PRC.
Originally Posted by paulu View Post
Hi Arragonis,
Yep - similar conversion (AFAIK ).
The conversions usually include valve lubrication kits too.
Old 11-02-2011, 07:45 AM   #39 (permalink)
Eco-ventor
jakobnev's Avatar
House of Tudor
Team Mazda
Plug-in Hybrids
At least the ones i usually see around Stockholm they are mostly BG50 and even BG100 sometimes. BG meaning bio gas and the number being the percentage. And the bio component is made from local waste.
Old 11-02-2011, 01:13 PM   #40 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Its odd in Europe that LPG is cost effective, over here LPG costs as much as Diesel Fuel or gasoline (once oranges are converted to apples energy wise)
I looked at LP carefully and it ends up within a penny or two fuel cost just like diesel (using the 1.5x conversion factor)
Anyone know in WI where you could get LP at a lower rate that would make it ACTUALLY worthwhile?
