Old 10-03-2010, 05:05 PM   #1 (permalink)
mechman600's Avatar
Fusion - '16 Ford Fusion Hybrid SE
Need help from electronics wizard please
Basically, I want to turn a circuit on when my vehicle reaches a certain speed. So, what circuit do I need to build to take the signal from my VSS signal wires and once the frequency reaches a certain speed close a circuit?
I am messing around with my TC lockup. Typical ford lockups: lock-unlock-lock-unlock-lock-unlock.....all with the very slightest throttle movement. I want to "fix" this.
Thanks in advance.
Old 10-03-2010, 05:34 PM   #2 (permalink)
Wiki Writer
bugler - '91 Mazda 626
90 day: 35.89 mpg (US)
Hi Mechman,
I am sure there are many ways to do this but with a quick search on voltage to frequency converters i found this chip which will do what you want
LM2917 - Frequency to Voltage Converter
on page 8 it even has a circuit for a speed switch so it looks like exactly what your after.
good luck
Old 10-03-2010, 06:31 PM   #3 (permalink)
mechman600's Avatar
Awesome. Thanks!
Page 8 contains exactly what I'm talking about. How would I control/adjust what frequency is required? By a variable resistor on pin 3? And what size of capacitor would I use on pin 2 & 3, or do I just go by picture above it?
Old 10-03-2010, 07:25 PM   #4 (permalink)
Wiki Writer
There is a little writing above the diagram on page 8 that has
load is energized when f>1/(2*R*C)
So set your resistor and capacitor appropriately and you should be fine.
If you choose a set capacitance then you can use a variable resistor to change the speed at which the TC will lock using the resistor.
So i dont know the frequencies you will be looking at but say you have a 1 uF capacitor and a variable resistor that goes between 0 and 500kohm you will get a frequency selection between infinite and 10Hz. You will not get very good accuracy if the frequency is too high with these R and C values.
I suggest playing around with the numbers and see what you get, you can always change the R and C later on if it doesn't work for you as well.
Old 10-03-2010, 10:56 PM   #5 (permalink)
mechman600's Avatar
Awesome.
Need help from "the electronics guys" mechman600 EcoModding Central 2 04-06-2010 11:53 AM
toyota sales halted (of 8 models) luvit The Lounge 71 03-21-2010 11:38 AM
Electronics repair question, any EE's? shovel The Lounge 4 12-25-2009 02:02 AM
Electronics guys? Daox The Lounge 10 01-07-2008 04:54 PM
