Old 01-06-2010, 12:01 AM   This thread is in the EcoModder Project Library | #1 (permalink)
puddleglum's Avatar
Rondo - '07 Kia Rondo EX
Last 3: 20.47 mpg (US)
Tinkertoy2 - '00 Toyota Echo base
Last 3: 46.03 mpg (US)
New front air dam
I thought it was time that I stopped just reading about mods and tried experimenting with one so I built a front air dam last weekend. I'm quite happy with the look (the less important part) but I'm not sure yet if it is going to help MPG. I already mounted a partial front pan last year and redid my grillblocks in the fall. Lowest suspension parts are at 6" and bottom of dam is 5.5". Eventually I would like to do a full pan and widen the front bumper to clear the tires but that is not an outside project at -20c. Anyway, I had a 200mile highway run yesterday that I make occasionally and mileage was only 8L/100km avg. at 65-70mph but -20c to -12c temp may have had some effect. I avg around 7.6-7.8 in the summer if the winds not blowing hard. I need to do some sort of A B A test when it warms up to be sure I guess. It may be too low or maybe I should have left the middle open. It may be creating more turbulance at the front tires since it doesn't clear them even though I tried to deflect it out at the end. I would appreciate your feedback. I was going to post pictures but apparently the file sizes are too big.
Old 01-06-2010, 01:48 AM   #2 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
puddleglum -
The album feature will upload any size JPEG. Go as follows :
User CP -> Pictures & Albums -> Add Album
Create an album and add a picture to it. The album will automatically downsize the image to fit. Then click on the picture and you will have a "BB Code" text of the image that you can copy into your post.
CarloSW2
American Solar Energy Society
Old 01-06-2010, 06:13 PM   #3 (permalink)
epic stock master
luvit's Avatar
86 Accord LX (carb) - '86 Honda Accord LX
90 day: 35.57 mpg (US)
i'm so confused. you talk mpg, mph, & 200 miles. but you posted 8L/100km.
so i did some research.
you got 29.40 mpg
according to this site: http://www.pege.org/fuel/convert.htm
single person car thread
Old 01-06-2010, 11:48 PM   #4 (permalink)
puddleglum's Avatar
Carlo, thank you for the help, I'll try this again. Luvit, sorry about being confusing. I was trying to use US terminology, but I do everything in metric and I didn't take the time to work out the conversion.
Here is my second gen. grill block with adjustable lower baffle and the pan before adding the air dam.
This is the filler pieces I built to tie into the small factory air dam and a piece of vinyl siding starter strip and some rubber cove molding that made the air dam.
Here is some assembly and the finished product.
Sorry that some of the pictures are dark but please tell me what you think. I
The Following User Says Thank You to puddleglum For This Useful Post:
k.civic.f4i (01-07-2010)
Old 01-07-2010, 12:01 AM   #5 (permalink)
epic stock master
luvit's Avatar
grill blocks look great!
by the way, how cold has it been for you this week?
Old 01-07-2010, 01:33 AM   #6 (permalink)
puddleglum's Avatar
lows have been around -5 to -15F with windchills -15 to -25F. Highs around 0 to 10F. Not as bad as a few weeks ago, hit -40. It's supposed to warm up this weekend though.
Old 01-07-2010, 02:42 AM   #7 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
puddleglum -
Excellent execution! I like your choices of materials. We usually see garden edging for this kind of stuff.
I see you have a block heater "ceegar" (plug), so to speak, ha ha. ... Or maybe a battery trickle charger plug?!?!?
CarloSW2
Old 01-07-2010, 03:35 PM   #8 (permalink)
Getting BETTER Mileage
Jethro's Avatar
Lucky No 19 - '11 Ram 1500 Express ST
Venti - '13 Ram 2500 Tradesman
That is one of the cleanest set of mods I've seen. Looks totally stock!
BTW, What kinda vehicle is that? I can't place it.
Old 01-07-2010, 03:38 PM   #9 (permalink)
90 day: 51.82 mpg (US)
Clean looking work.
It'd be great if you make a garage entry for the car. Then we'd all be able to figure out what it is.
Old 01-07-2010, 03:51 PM   #10 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Love the grille block. It almost looks like a factory option!
"żʞɐǝɹɟ ɐ ǝɹ,noʎ uǝɥʍ 'ʇı ʇ,usı 'ʎlǝuol s,ʇı"
Comparing Warm Air Intakes (WAI) & Cold Air Intakes (CAI) toomuch EcoModding Central 27 11-20-2022 04:24 PM
start to play with IAT sensor on Mercedes E250D-Turbo 98' poisas EcoModding Central 6 10-07-2013 04:13 PM
2007 Focus Front Air Dam garys_1k Aerodynamics 23 12-28-2011 02:22 PM
Moving air intake into the engine compartment? pasadena_commut Aerodynamics 5 07-25-2008 03:24 PM
First aero-mod: front air dam jim-frank Aerodynamics 2 05-21-2008 09:43 PM
