Old 11-29-2014, 01:03 PM   #1 (permalink)
Alfa - '03 Alfa Romeo 156 2.5 V6
New guy with Alfa V6
Greeting from Hong Kong,
My car is a 2003 Alfa Romeo 156 2.5 V6 6spd. I have this car for 5 years but only recently I wanted to explore the ways for drive her more economically. I started my hypermiling since half way of last tank of gas, and the result was promising as already seeing 0.7km/L improvements as shown from the trip computer.
here is a list of mods I have currently
1) alu under engine tray
2) lowered suspension
3) high performance air filter
4) high performance 2.5" cat-back exhaust
Today I have removed the front strut bar to save some weight
Next idea I have is to improve on low-rev power since my experience with hypermiling will use more low-rev range about 2k~ 2.5k rpm of the engine.
I am considering ECU remap as I read it improve all range engine efficiency and adapt with aftermarket mods that I have (air-filter & exhaust) and generally provide better fuel efficiency when drive sensibly.
I see many physical mods being recommended here however I do not found much info about chipping their vehicle. Can someone please share their experience ? or what kind of results should I be expecting?
Thankyou for reading
Old 11-29-2014, 04:46 PM   #2 (permalink)
la_voiture_de_courses - '03 Renault Megane Estate
OldContinents
90 day: 44.34 mpg (US)
xiao lan - '01 Audi A2
90 day: 38.88 mpg (US)
Brit iron - '92 Mini Mini
90 day: 45.5 mpg (US)
Prius - '09 Toyota PRIUS Lounge
90 day: 47.37 mpg (US)
Beemer - '06 BMW F800 ST
90 day: 53.06 mpg (US)
Hello and welcome.
I am not very knowledgeable about chip tuning on gas engine but I believe it has to do with boosting fuel pressure to restore performance potential that is already there before the car emissions are taken into account.
I don't think chip tuning is gonna allow for more MPG out of a gas engine.
At least it depends on the route you have to use.
Maybe if you do a fair amount of highway it can improve the pulse of your pulse & glide ?
Old 12-01-2014, 10:13 AM   #3 (permalink)
Thankyou for your feedback, for petrol non-turbo ; all I know is that it suppose to optimise its air/fuel ratio on different spots on the rpm curve, advance timing as well as improve throttle responds. Thats why I want to see what you guys thinks.
I havn't understood what pulse & glide means, I'll read on more soon.
Old 12-01-2014, 01:13 PM   #4 (permalink)
Pulse and glide means you accelerate at an efficient pace, and once you hit a certain speed, you disengage and coast. That could be engine on (idling) or engine off coasting. Once you hit your lower speed limit, you accelerate again and coast again.
I am not a fan of engine off coasting for safety reasons...
But that's what pulse and glide means.
troy
2004 VW TDI PD on bio
want to build 150 mpg diesel streamliner.
The Following User Says Thank You to solarguy For This Useful Post:
pingchan71 (12-03-2014)
Old 12-03-2014, 01:22 AM   #5 (permalink)
OldContinents
And it is more worth the hassle at certain speed : above 50 km/h / 30 mph
