Old 03-04-2013, 12:24 AM   #11 (permalink)
Probably partly both. It's a secondhand, but even brand new old-school Suzuki automatics slip like hell. I had a van for a week that never locked up the torque converter in traffic... EVER. Annoying, and expensive to gas up.
The short gearing does play a role, but if it was only that, simply never going above 60-80 km/h should do the trick. I don't think it will.
Old 03-04-2013, 03:20 AM   #12 (permalink)
Honda100's Avatar
MetroScoopy - '09 CHF50 Honda Metropolitan 50cc
90 day: 97.98 mpg (US)
Training Shoe - '99 Hyundai Hyundai Atoz Prime 797cc
90 day: 31.28 mpg (US)
I think the trans is mostly to blame, but also that the older Hyundais like this just aren't as good on gas for whatever reason. I don't know why, but that's the way it seems it is. I had an Elantra which was a fantastically reliable car, but it never saw the other side of 30 mpg on the freeway. 22-28 was all that ever came out of it.
Tires: As of now the tires are at 40 psi (max sidewall = 44), and the wheels are already alloys. I got a flat tire yesterday and changed it. The steelie in the boot was noticeably heavier. Also, in Cambodia there are no RX7s or AE86s and importing wheels would be too much for too little gain I imagine.
Package Features: This car came straight from Korea (I'm the first owner here in Cambodia), and it seems like the Korean market cars come in any shape, package, etc. Makes sense, seems how Korea is one of Hyundai's biggest markets.
Anyway, I am starting to think maybe I might be stuck with sub 40's for mileage, considering I'm not willing to go for a standard transmission.
1988 Honda Super Cub 50cc
Old 03-06-2013, 03:11 AM   #13 (permalink)
Why would you avoid a manual transmission? BTW how hard might be to get a 4-speed (with overdrive) automatic transmission to retrofit into the Atos?
Old 03-06-2013, 12:07 PM   #14 (permalink)
darcane's Avatar
You've got some things working against you, but you still have some options. In my pickup, I was still able to get ~25% improvement even though it had an auto.
You can pulse and glide (Engine-on, it's an auto) and coast to a stop as well as abunch of other techniques.
Aero tweaks will help, especially for highway driving. Lose the mudflaps. It's not a side profile shot, but from the pics your spoiler looks like it is kicking upwards which won't help. Lose the spoiler or see if you can modify it to fit the aero profile a bit better. The usual grill block and air dam or belly pan would help. Look for tires with lower rolling resistance when these need to be replaced.
It's not one big magic pill, it's a hundred mundane motes.
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
Old 03-06-2013, 02:30 PM   #15 (permalink)
3-Wheeler's Avatar
AlienMobile - '00 Honda Insight
90 day: 80.05 mpg (US)
Hi,
38 mpg sounds too low. Especially considering the small engine size.
My daughter's Toyota Echo MT was ScanGauged two years ago at 55 mpg at 45 mph on a dry, flat road, in the summer. Her engine size is 1.5L, and your's is almost half that.
Jim.
Old 03-07-2013, 11:36 PM   #16 (permalink)
Honda100's Avatar
If you Google Cambodia Traffic, you'll see why. 4 speed? Probably no dice, there is barely any space for the miniature trans it has.
I would, but it's a cover to a frame underneath which is the structure to contain all the wires and such. That structure is bolted to the hatch and looks awful without it (all the holes, etc.)
For me I think the best mods are going to result from fuel maps and/or fudging with the O2 sensor/map sensor, etc. because my avg. speed right now on my scangauge equivalent says 14.5 km/h, which isn't even 10 mph. Any aero mods are going to be useless I am thinking, considering the driving I do.
P.S. I also adjusted the ignition timing (I noticed it starts to ping a little under a load when hot) and the mileage seems to be a little better. Usually at 100 km I am below 1/4 tank, but now I am slightly above. Anyway, I know the stock fuel gauge is inaccurate, but you can still judge vaguely on it.
Old 03-08-2013, 03:53 AM   #17 (permalink)
I never went to Cambodia, not even considered to do so, but really, the comfort of an A/T in heavy traffic really pays back. Also, under certain circumstances, the higher expense with fuel is still cheaper than fixing a worn-out clutch
Old 03-14-2013, 09:53 AM   #18 (permalink)
Honda100's Avatar
Haha, I am getting depressed. At 360 km I was out of fuel (just 5 liters left in the tank) which translates to 29 mpg.
I'm going to get the transfluid changed and switch over to synthetic oil, I am sad at my mileage. Although I can't complain I guess, my 1.6 Corolla only manages 17-18 mpg.
Old 03-14-2013, 08:27 PM   #19 (permalink)
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
You could sell it and get something else..... Probably that's not a very doable option.
Coast long and prosper.
Old 03-14-2013, 08:35 PM   #20 (permalink)
So does my V8 4x4 F150.
