Old 03-16-2014, 06:14 PM   #11 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
bump
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 04-10-2014, 04:26 PM   #12 (permalink)
Horse with no name - '00 Ford Mustang Base
Team Mustang
90 day: 20.53 mpg (US)
Orange peel - '00 Ford Focus SE
90 day: 26.83 mpg (US)
Not true, a completely plugged air filter will result in 0 MPG, as in the engine will no longer run.
If it is removed it will result in the same 0 MPG from the engine dieing of sludge.
Old 04-10-2014, 05:29 PM   #13 (permalink)
dirty air filter
I thought that ICE is an air pump and if it has to work harder to suck air through it will take a little more energy to accomplish this. apparently not a lot.
Paul
Old 04-10-2014, 07:47 PM   #14 (permalink)
vskid3's Avatar
Civic DX (sold) - '97 Honda Civic DX
90 day: 34.15 mpg (US)
GTO (sold) - '04 Pontiac GTO
90 day: 22.62 mpg (US)
Green Brick (sold) - '06 Ford Escape Hybrid
90 day: 31.93 mpg (US)
Paul
The throttle plate is still the biggest restriction unless you floor it, which is why there's a reduction in peak power.
Camry Thread
E-Bike Thread
Old 04-10-2014, 09:53 PM   #15 (permalink)
mcrews's Avatar
Read the article, then post... ..works better that way
ECO MODS PERFORMED:
First: ScangaugeII
Old 04-11-2014, 05:48 AM   #16 (permalink)
I'm not really willing to use this as an excuse to neglect maintenance...
Joggernot (05-04-2016)
Old 04-11-2014, 07:18 PM   #17 (permalink)
Team Mustang
Huh?
The article studied putting show towels over the air filters to simulate a plugged filter to see the effect on MPG. In the real world the filter will either eventually become completely plugged so the engine will no longer run, or the filter will collapse under the vacuum and the engine will slowly fill up with dirt until it no longer runs. Both will result in 0 MPG.
I have seen both, the filter plugging is the easiest fix. Working on a sludge engine is horrible.
If you are saying that this studies says your Otto cycle internal combustion engine no longer needs oxygen to burn fuel then you had better reread the study yourself.
Old 04-11-2014, 07:57 PM   #18 (permalink)
Drive less save more
ecomodded's Avatar
90 day: 60.42 mpg (US)
I to have thought that a restricted intake would increase mpg , I think that's why my vw tdi gets such great mileage, it has 225,000km on it and the 1.9 tdi is notorious for clogging its intake from the EGR.
In effect lowering the cars hp and subsequently the fuel consumption as the cars computer always maintain a clean burn threw the fuel injectors.
I expect when and if I clean my intakes filth out my hp will increase and economy will decrease, unless i can drive like a saint 100% of the time.
Save gas
Old 04-12-2014, 12:38 AM   #19 (permalink)
But Diesels tend to run leaner, so the clogging at the intake might make it just roll a little more coal instead of improving the fuel-efficiency, plus at a certain point you'd have to keep the RPM higher to get a certain amount of power...
Old 05-04-2016, 10:07 AM   #20 (permalink)
mcrews's Avatar
bump
ECO MODS PERFORMED:
First: ScangaugeII
Comparing Warm Air Intakes (WAI) & Cold Air Intakes (CAI) toomuch EcoModding Central 27 11-20-2022 04:24 PM
Hydrogen Generator Experiment willy57 DIY / How-to 601 08-23-2016 05:53 AM
Honda IACV explained TomO Off-Topic Tech 16 12-21-2015 01:49 AM
mileage computer for a carbureted engine diesel_john Instrumentation 221 05-01-2014 10:38 PM
Emissions Standards - "Good For Fuel Efficiency," Consumption Data Says trebuchet03 General Efficiency Discussion 11 04-18-2008 01:15 AM
