Old 06-10-2011, 10:16 AM   #1 (permalink)
Muscle Car Modder
Floordford's Avatar
QuikSilver - '00 Ford Mustang GT
90 day: 24.7 mpg (US)
What engine only mods for better efficiency?
What can be done to a good running engine to make it more efficient? By that I mean it already would have good plugs, coils, new oil, new air filter, etc. basically in great running order.
My thoughts go to polishing the intake and exhaust ports on the head so that the engine strains less. Possibly a slightly bigger exhaust system. Or more powerful coils for better combustion. A custom grind cam, but it would be very much blind guessing. Higher compression for more power with less throttle. Lighter rotating assembly like a lightweight flywheel, crankshaft, valves, cam gears, rockers, spring retainers.
I also wonder what makes for a more fuel efficient engine as means to more horsepower or more torque. By that I mean, some cars have long intake runners to make more torque. Other cars have short intake runners to make more horsepower. No doubt this would need to get matched with things like cylinder volume, bore, and stroke. But one or the other might fetch better efficiency.
Most of my ideas come from making an engine more powerful to race but it stands to reason that if an engine doesnt have to strain as hard to make power then it should get better MPGs. So long as those mods dont cause it to use more fuel.
2000 Mustang GT
273hp/ 309ft.lbs.
Cd 0.36 Im working on it
Old 06-10-2011, 10:34 AM   #2 (permalink)
Nope.
Nope, unless its turbocharged.
Nope (ok, maybe marginally, we're talking a fraction of an mpg)
Yes, but only if the custom grind increases low end power.
Yes, but only to the point at which it starts effecting timing and you have to retard it which eliminates any benefit. So, this is a very hard thing to balance.
Yes. Included in this are piston rings that aren't as tight, OEMs have used these on recent engines to improve efficiency. They've also used offset crankshafts to reduce friction losses.
The easiest and IMO best thing to do to increase engine efficiency is to use a smaller engine. Increasing the load DRASTICALLY increases the efficiency of the engine. If the power output isnt enough, add a turbocharger.
The Following 2 Users Say Thank You to Daox For This Useful Post:
cleanspeed1 (06-10-2011), nemo (06-10-2011)
Old 06-10-2011, 12:14 PM   #3 (permalink)
Diesel Addict/No Cure
cleanspeed1's Avatar
StolenHoopty - '90 Honda Accord EX
HvyDrnkr - '93 Cadillac Seville
Let's take a look at the differences between the 4.6 Modular ( 2V ) and the 5.0 Ford.
Reduced bore for lower emissions
Low fiction valvetrain
Low friction piston rings
Undersquare bore to stroke ratio
Fast burn combustion chambers, small valves and ports for high velocity
Long runner intake manifold
For economy, the closer you can keep it to stock, the better it will run because it was optimized from the factory to run in the lower ranges most of the time. Anything that enlarges the ports lowers the velocity of air into the port at lower rpms, unless there's a displacement increase or some form of supercharging. Headers are not bad if they are built for no compromise in tube size and length, along with collector dimensions.
Cam timing, overall tune and gearing are the arbiters.
Volvo WIA42 VED-12 / 335 hp / 1300 ft/lbs / 9 mpg
Big n' Boxy, Never met a Hill it Didn't Like
Old 06-10-2011, 01:41 PM   #4 (permalink)
As has already been said, the biggest thing you can to do an engine to reduce its fuel consumption is to replace it with a smaller one.
Another really major thing you can do is to not use it. Turn it off when you're sitting at a light, turn it off when you're coasting, and so forth.
Another thing is to operate it in its most efficient regime, typically right around 2000 RPM with a decent amount of load on the engine. Which means pulse and glide (or pulse and coast).
If you're talking about modifying an existing engine to get economy out of it, you can easily spend thousands or tens of thousands of dollars making changes that can get you a couple of percentage points of FE. Not worth it in any way, unless you're looking to set records. (In which case, the "smaller engine" idea is probably a better way to go.)
Since efficient driving is all at low RPMs, any changes you make that help the engine to work well at low RPMs have a chance of improving economy. Long tubular headers are one thing that comes to mind. A cam ground for torque at very low revs is another. A long-tube type intake might be as well. Increasing bearing clearances for low-friction operation. Friction reducing coatings on moving parts and on oil-shedding parts. Compression increases will help, possibly at the expense of requiring higher-octane fuel. Smaller valves to give good flow velocity at low RPMs. Lighter everything (including valve springs) so you spend less energy moving things around. And so on.
And all of that might net you, what, a 5% improvement if you're lucky?
Actually, one other area where engine mods can help fuel economy noticeably: If your engine has really major shortcomings or design flaws, correcting those can help. A friend with a 60s-vintage Mustang saw better economy when he replaced the awful stock exhaust manifold with real headers, for example.
Cars built in the last 30 years or so won't have easy gains like that available, though. When automakers had to start building for economy, they grabbed the low-hanging fruit first.
-soD
Old 06-10-2011, 02:52 PM   #5 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 80.56 mpg (US)
Send a message via MSN to jakobnev
And the really good ones have Variable Resonance Induction Systems.
Old 06-10-2011, 04:37 PM   #6 (permalink)
Muscle Car Modder
Floordford's Avatar
Well my project behind the thought was to pick up a small fuel sipper and pull the engine before I start relying on it. I can make the changes while its down.
It seems as though polishing the intake and exhaust should work. Im not talking about a major port job where alot of material is being removed. Just a smoothing out of the rough surfaces left by low cost factory castings. Another thought was to actually add material. With the head and intake off material could get welded on to create even more of a tapered velocity effect. Or fill in bad imperfections from bolt mountings. I figure just like the front of a car benefits from being smooth so would the air getting inside the engine.
And I know smaller engines make for better MPGs. But if im working with a car that already has the base line engine then my only option is to either go back in years to see if an older motor with smaller displacement might retrofit or work with what the manufacturer installed. Thats why I wanted to know what mods I can do to an engine can benefit it. No matter the engine. So say i did swap it for a smaller engine, my question still applies.
I also wonder how honest oil companies are when they sell eco and gas saving oils. Thinner oils might do well and synthetics are even better. But I wouldnt run synthetic in my transmission unless recommended by the manufacturer. The reason being is that slippery synthetics can cause the synchros not to grip with the needed friction to help the gear change causing hard shifts.
2000 Mustang GT
273hp/ 309ft.lbs.
Old 06-10-2011, 06:22 PM   #7 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
People who want more power often talk about making the engine breath better, or that they want a better flow in the exhaust or intake, but engines don't operate off a continues flow, they operate off pulses and those pulses have to be tuned, that is why you do tune ups, keep your engine in tune because an engine fallows alot of the same rules as music because they both run on pulses! fallow the math and design for those pulses and you will use less gas, engines are designed to run over a wide range of engine speeds so tuning it for power, or for gas mileage and you will slightly limit the RPM range that it will run in, unless you have variable intake, this is why cars that are tuned for racing are the worse cars to drive in slow traffic, cars that are designed for gas mileage don't race well.
Old 06-10-2011, 06:39 PM   #8 (permalink)
Engineering first
bwilson4web's Avatar
17 i3-REx - '14 BMW i3-REx
Last 3: 45.67 mpg (US)
Blue Bob's - '19 Tesla Std Rng Plus
Perhaps you are ready for two cars:
  • existing toy car - enjoy but only drive it for fun.
  • assorted fuel efficient, earn a living car - so you can make the bucks for the fun car
In the fuel efficient mode, you could go with a really old, 1970s or earlier, simple car, bought for peanuts. Plan to replace the tires and possibly a drop-in engine. At about $5-7k, you're on the road and only throw in enough to keep the beater rolling. But the engine and drive train technology would be familiar and you'd be on the road, earning, with the toy car as backup.
Another approach would be to look at early 2000 hybrids. The options are limited: Prius, Insight or Civic. If you want more traditional, go with the Hondas. The advantage is there are is a lot of historical tweaking data. On the Hondas, go for a manual transmission ... you'll be a lot happier.
There are other options but they require . . . different skills. No need to tackle 'a bridge too far.'
Bob Wilson
2019 Tesla Model 3 Std. Range Plus - 215 mi EV
2017 BMW i3-REx - 106 mi EV, 88 mi mid-grade
Retired engineer, Huntsville, AL
Old 06-10-2011, 07:28 PM   #9 (permalink)
balance the injectors so that they all perform the same. will help your car to adjust A/F mixture more accurately.
Old 06-10-2011, 08:15 PM   #10 (permalink)
Are you talking about working the car you currently have or getting something else?
If you want to use the existing platform, how about a turbo 2.3L?
Stock, blueprinted build, stock intake manifold ( runners equalized, but not enlarged and gasket matched )
High torque cam with roller followers with peak torque in the 1800-2000 rpm range
Turbo header sized best for off boost performance
Dual staged efi with 4 primary injectors optimized for mpg and 4 for boost enrichment
Turbo sized for whatever hp level.
