Old 02-15-2012, 12:27 AM   #1 (permalink)
Horse with no name - '00 Ford Mustang Base
Team Mustang
90 day: 20.53 mpg (US)
Orange peel - '00 Ford Focus SE
90 day: 26.83 mpg (US)
Gas mileage loss with wider tires?
I am looking for new wheels and tires for my 2000 V6 mustang. I found some for a good price but they are very wide. They are 275 wide compared to the stock tires of 205. They will be summer tires and not the M/S I normally run in the summer. They will be 17" wheels verses the 15" I now run meaning total weight will be less. I was wondering if anyone had any real would experience on wider tires and fuel mileage?
Old 02-15-2012, 01:27 AM   #2 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
actually, unless you have already weight them, the probably weight more.
And unless the are a little taller, your screwed.
they are stickier so they wont roll easy.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 02-15-2012, 01:43 AM   #3 (permalink)
Ladogaboy - '11 Mitsubishi Lancer EVO GSR
Team Emperor
90 day: 27.64 mpg (US)
E85 EVO - '11 Mitsubishi Lancer EVO GSR
90 day: 21.38 mpg (US)
There has been some information posted stating that wider tires have a lower coefficient of rolling resistance (i.e., lower rolling resistance than their narrower counterparts), but I'm not sure how that translates into real world mpg. Your mileage is affected by aerodynamics more than rolling resistance, so having a wider tire might still cost you mileage despite the decrease rolling resistance.
That being said, the composition of the tire is more important, and M/S and summer tires are probably equally bad on mileage. Most of the good LRR tires are A/S. Also, if the tires are taller, you'll gain a few % just based on fewer rotations per distance traveled.
Old 02-15-2012, 07:20 AM   #4 (permalink)
Tire Geek
CapriRacer's Avatar
While wider tires have less rolling resistance, the effect is small compared to the differences between tires. At 275 width, you're in the range where RR is not the desired attribute and the tires don't have good RR - and summer tires will be worse than all season tires.
With the 15" tires, you are much more likely to find tires that meet your excpectation for fuel economy/traction/treadwear, all 3 of which are tradeoffs.
Choose wisely.
Old 02-15-2012, 08:01 AM   #5 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
If you've been happy with M/S (didn't you mean A/S ?) tires in summer, I'd say you don't need 275 wide tires.
A dedicated, decent summer tire will outperform the all seasons, and Mud and snow variety.
Even sporty tires can't escape the current trend towards greener tires with less RR, so you can nowhave tires that combine good performance with reduced RR to get good mileage.
Unsprung weight will most likely increase with bigger wheels, unless you've deliberately chosen lighter wheels.
Lower profile tires on the 17" wheels will be heavier per inch of rubber they add to the diameter, so that's another weight increase.
Old 02-15-2012, 12:37 PM   #6 (permalink)
Team Mustang
Thanks for the replies. The reason I am getting new rims is to prevent the rush to get studded snow tires put on/taken off when the law allows. If I can do it myself it would be a lot easier.
Buying used wheels for my car seems impossible, the places I go say that they are all damaged from hitting curbs. I guess there are a lot of bad drivers out there. I have not found any after market 15" wheels I can afford, If I could that is what I prefer to use.
I see now that these tires are probably way too wide to not effect aerodynamics. I am going to install splats but I didn't want them to stick out from below the car.
Paul
Old 02-15-2012, 03:06 PM   #7 (permalink)
mcrews's Avatar
Paul,
sometimes 'opprotunities' arise and we have to weigh the choice.
Decissions are not always as clear cut as someone looking from the outside says it is.
For example: I REALLY want clear flat wheel covers BUT I have factory alloy rims and I'm not going to drill holes in them to hold the clear cover on. Nor am I going to change to a steel rim and do flat wheel covers.
But atleast you have some more information than you had before.
I would find some nice piece of higway and do an 'a' test now and then a 'b' test with the new setup.
ECO MODS PERFORMED:
First: ScangaugeII
Old 02-15-2012, 03:46 PM   #8 (permalink)
basjoos's Avatar
Aerocivic - '92 Honda Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Honda Civic CX
90 day: 55.14 mpg (US)
Camryglide - '20 Toyota Camry hybrid LE
90 day: 65.83 mpg (US)
Paul
Go look for "take off" wheels. These are the OEM wheels that some owners have removed (and trade in) when they buy a set of fancy new wheels for their new car. You can often get them next to new for very low prices since they are OEM and aren't considered "cool" by the automotive performance crowd.
aerocivic.com
Old 02-15-2012, 08:04 PM   #9 (permalink)
Elle - '10 Honda Element SC
if your wheels are toast. I have a set that would work with only 13k miles
they are not 15s. there 18X7s +45 with 225/55-18 they should be the 2005+ mustang diameter if not slightly larger. and prob much more efficient then 275s.
let me know if yer interested and you can test em out.
I picked up 19s and im getting 16s for winter so these will be of no use they were the oem they have a nice flat lip for a lexan wheel cover.
btw. if you dont mind me asking whats your budget? I can atleast help you source some 15s
Old 02-15-2012, 08:21 PM   #10 (permalink)
The main factor is increased aerodynamic drag from the larger frontal area, not rolling resistance.
fuel, mileage, tires, wider
