Old 02-10-2010, 10:45 PM   #31 (permalink)
AeroModder's Avatar
Tank - '96 Ford Aspire 4 door
Team Ford
90 day: 46.75 mpg (US)
Thanks for the info. I found the wiki page on it, and the only trouble should be finding the wires. I've hooked up a pair of driving lights and a tach, so this shouldn't be too hard.
Though it's going to need to wait until I have the funds..
From looking at my bumper, I could pretty easilly make a 5" long air dam, but the trick is going to be getting the coroplast to curl around the corners. I'll probably pre-bend them first, then go pick up some mounting hardware for a few bucks. I'll try testing that after I test switching back to the Fram filter.
In Reason we Trust
Old 02-11-2010, 05:56 PM   #32 (permalink)
Originally Posted by Christ View Post
You're going tank by tank and testing mods with each tank?
Why not try eliminating some variables and running each mod for more than one tank?
If you get a 5% increase from a mod, with your 22mpg, it's only going to equate to ~1mpg, Mike.
There are so many problems here, the biggest being there is something quite wrong with the car, the driver, and/or the car/driver combo.
You can't "mod" something and expect results if it ain't even working right in the first place.
The a/t Tempo in stock working order should be returning 27-32mpg. Get there and THEN mod otherwise there really is no point in dicking around.
Old 02-12-2010, 02:22 PM   #33 (permalink)
90 day: 51.82 mpg (US)
If you have MPFI, you should be able to use the MPGuino.
It works on single injector / throttle body type systems too.
Christ (02-13-2010)
Old 02-13-2010, 02:02 AM   #34 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Couldn't find where it said yes to those, so I didn't want to go ahead and say it would. Thanks!
Old 02-14-2010, 05:05 PM   #35 (permalink)
AeroModder's Avatar
Team Ford
Okay, so here's what I'm looking in to:
I already mentioned the air filter. I'm going to test to see if the lower-flowing Fram air filter will help mileage, since that should reduce the amount of fuel the EFI puts in.
I recently replaced the front struts and springs, which seemed to raise the front end an inch. I swapped the stock springs for Moog variable-rate cargo springs for a firmer ride. I'm wondering if I put the old springs back in if it will make it sit back down a little.
The air dam was mentioned before, and I still need to work on making a design and testing it.
My current tires have a treadwear rating of 420, which indicates that they're a softer compound, giving more rolling resistance.
Even with my current performace mods, I'm still just above the EPA's mileage for a stock Tempo (Even in the winter with wind and rain!). This is telling me that my eco mods are helping, but if I sacrafice performance, I can go even further, possibly reaching my 30 MPG goal. I'm hoping to have interchangeable parts for economy and performance (a set of grippy tires on wider rims and LRR on my stock rims, two different air filters) so I can switch between the two as needed. It will be interesting to see what effects on performance and economy each part has. I'll likely do some acceleration, braking, and cornering tests with each set as well as mileage tests.
Update: With rain all last week, and one day of heavy storms (in which I needed to drive faster than normal to keep up with a friend, who was leading me to his place), my tank mileage dropped to a hair over 20 MPG. This week is calling for higher temps and less rain, so we'll see how it goes.
I replaced the K&N filter with the Fram paper filter, and at first start the engine was quitting from the reduced flow- the ECU didn't recalibrate just yet. On the drive to class, I noticed the engine was running slightly warmer and there was a noticeable drop in power (It didn't have the lively acceleration the increased airflow gave). We'll see what effect on economy it has when I use up this tank. I'm low on cash at the moment, so I hope I can squeeze at least a week and a half out of this one.
In Reason we Trust
efficient engine design user removed EcoModding Central 27 11-24-2014 01:02 AM
PCB design for led bargraph battery monitor mora DIY / How-to 30 10-20-2011 11:02 AM
Win $100.00 in Free Gas! Design Contest: Ecomod my Ride XFi EcoModding Central 127 02-17-2011 12:07 AM
Efficient Engine Design ??? pgfpro EcoModding Central 110 02-12-2010 01:53 PM
Civic grill block, front undertray, tire deflectors daqcivic Aerodynamics 24 05-13-2009 03:52 AM
