Old 03-25-2012, 06:33 PM   #1 (permalink)
civic - '98 honda civic ex
90 day: 42.17 mpg (US)
New to forum
Hello everyone. I'm glad I found such a great site. A very good read with top shelf advice.
I have a 98 civic 2-door coop with 166K on the clock. My best tank with no mods was 42mpg. It is my 62 mile DD, (half highway miles). I just refilled and got 40 mpg today. I am looking forward to trying some of the hypermiler techniques. I already drive like an old man according to my daughter. A few mods to start with will be radiator block and air dam.
A couple of questions. Is zero toe safe? Will a mini kamm on the trunk deck have much value? Due to WAF (wife acceptance factor) no full kamm or boat tail. Regards, Paul Q
Old 03-25-2012, 06:46 PM   #2 (permalink)
GRU
GRU's Avatar
silver bullet - '00 Honda Civic
90 day: 34.41 mpg (US)
Welcome. Even if a mini kamm helps 1-2% i'd put it on if it doesn't cost much to build.
I just got a 99 Civic Coupe and i was looking at the lines of the car. I think i might just use a sheet of coroplast from the top of the rear glass to the end/top of the trunk
The Following User Says Thank You to GRU For This Useful Post:
pdq54 (03-25-2012)
Old 03-25-2012, 07:05 PM   #3 (permalink)
Thanks for the reply
The old ball and chain vetoed the kamm off the roof line. I was wondering if a mini kamm on the trunk deck would have any value? Thanks, Paul Q
Old 03-25-2012, 08:57 PM   #4 (permalink)
larrybuck's Avatar
Location: sw Washington (state), a little north of Vancouver
0 toe might be ok if you don't drive very fast, and don't have to deal w much wind.
One of the cheapest things that might be a fun inexpensive project would be to decrease
or eliminate the outside mirrors especially since if you have a pass. side one.
Plenty of tips on here how to do that. A smaller driver's side can help reduce that flag effect!
Don't be scared to bump up your tire psi. at least by 5psi.
06 Chev MonteC JG#24tribute car 30mpg 00 Honda Insight 63MPG 98 Buick Park Ave3.8 33MPG 89 Toyota Corolla wag 53MPG so far 81 VW Rabbit diesel pu 50MPG+ 80 Mercedes 240D stick 30-ish 90 vette 6-speed,29ish 07 Honda ST1300 55MPG 83 Honda 650 GL 64MPG 19 Suzuki dr200 88MPG23 HondaGrom?+Tow K10D Sub 26mpg NEVER,NEVER GIVE UP!
PUMP THOSE TIRES UP!
DRIVE IN YOUR SOCKS FOR SENSITIVITY!!!!!!!!!!!!!!!
SLOW DOWN AND SMOOTH UP!!!!!!!!!!!!!!!!!!!!!!!!!!!!![SIGPIC]
The Following User Says Thank You to larrybuck For This Useful Post:
pdq54 (03-26-2012)
Old 03-25-2012, 11:13 PM   #5 (permalink)
CRX HF - '91 Honda CRX HF
90 day: 68.45 mpg (US)
Welcome to the forum!
The Following User Says Thank You to IsaacMTSU For This Useful Post:
pdq54 (03-26-2012)
Old 03-26-2012, 09:29 AM   #6 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
FYI, the 1st generation Honda Insight came with zero toe from the factory. I don't find it a problem at all.
pdq54 (03-26-2012)
