Old 12-18-2018, 11:06 PM   #51 (permalink)
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
Low hanging fruit in winter, in no particular order:
-LRR winter tires
-Tire pressure
-Warm air intake
-Grille block
-Block and oil pan heaters
LRR tires and high pressure are really great mods any time of the year. Beyond that, it's a matter of keeping the engine warm as much as possible. In my car, when it starts to cool off outside I pull off the plastic intake snorkel and replace it with flexible RV dryer ducting, which I routed from the intake to just under the catalytic converter. I can get air into the engine over 100F when it's subzero outside if I drive the car long enough to get everything warmed up. Warm air has a variety of benefits, but to summarize it, automotive engines are all heat engines. You're turning fuel into heat, and then extracting mechanical energy from that heat. During winter any heat you can redirect back into the engine which would otherwise be lost is like turning exhaust back into gasoline and putting it back in your tank.
Regarding the propane system, you mentioned that it "injects just before the O2 sensor" - the O2 sensor is in the exhaust, after the engine. You're definitely not injecting it into your exhaust.
The way I read it, it's injecting propane into your air intake, which is where your car injects gasoline too. Propane burns about as well as petrol in most engines, and propane has ~25% less energy content per gallon (which is to say how much heat it turns into when you explode it), so for every 1.33 gallons of propane you inject, that's one gallon of gasoline you're not burning - assuming the car is able to fully compensate for the extra fuel you're dumping into the engine. This will in fact save you money if propane is at least 25% cheaper per gallon than gasoline - again assuming the car is able to adjust its fuel maps enough so as not to run rich. Which might be why it's only really talked about in diesels.
My 2 cents: Propane is a great fuel, but the 30% savings claim is total bull. It might save you money in the long term but how much is going to be based entirely on the price ratio of propane to gasoline, and whether your engine will adequately reduce the amount of gas it burns when you add extra propane fuel. You'd effectively be substituting part of your gasoline with propane, there're no other magic savings to be had.
Old 12-19-2018, 10:22 AM   #52 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
Originally Posted by DeliveryGuy89 View Post
That interior looks like, and your geographical description really kinda sounds like Flying J out there, but there's no trophies anymore. It's a truck stop with a restaurant, casino and bar now.
Edit: My girlfriend says that it's here, but I've never seen it and the one she's saying it's in, I've never noticed anything there. So I have no idea lol.
Hmmm...I'll have to find it again the next time I drive through. I want to get pictures of the rest of it!
UIUC Aerospace Engineering
www.amateuraerodynamics.com
Old 12-19-2018, 02:02 PM   #53 (permalink)
We have had a few serious ecomodders with Subarus. Zerohour did cool things, but then bought a Mini, and disappeared. Who had the new blue Subaru with Plasti-Dip on the front?
I miss my 1999 Forester, but I do not remember why. Was it all of the gas that she used or the repairs that cost more than fuel? Was it replacing the head gasket? There was one very much like mine for sale up here for $1,200. She looked nice from the road, but what was wrong with her that they asked so little? Well, it seems she sold a day or two ago, so I will never know.
I need to replace the head gasket in my Civic, not another Forester.
By the way, my Ultragauge showed Bacon consuming .28 GPH at idle.
A couple of things that I always try to share: In all of the research that I have done on Subarus I have seen one post suggesting to replace the head gasket when you change the timing belt. The other is yay! The Boxster engine has a lower center of gravity! Except your entire car is higher, so where is your center of gravity now?!
Seriously, I miss my Subaru, but I miss the girl who used to drive it more.
Both required a great deal of time and attention.
Old 12-19-2018, 05:35 PM   #54 (permalink)
The Delivery Guy
The Hulk - '96 Subaru Legacy Outback
90 day: 24.33 mpg (US)
White Lightning - '12 Chevrolet Volt Gen1
I've heard Forester's are a lot more finicky than Outbacks, which I'm thankful I chose this one instead of the Forester the dealer was pushing me towards, haha.
Old 12-19-2018, 08:06 PM   #55 (permalink)
Moderator
Vman455's Avatar
That was jedi_sol; if I remember right, I think he sold that car before he disappeared from this site.
Old 12-20-2018, 01:46 PM   #56 (permalink)
The Delivery Guy
Got a link to his page?
And i've run into an interesting mechanical issue... Or maybe it's normal, idk. My odometer doesn't work during EOC?
I thought the odometer was tied directly into the manual systems. What would cause this?
It's gonna skew my results real bad lol.
Old 12-20-2018, 02:55 PM   #57 (permalink)
Are you key-off EOC or just killing the engine and leaving the key in the run position? My odometer doesn't work unless the key is at "run" either, works fine if I use an injector kill switch.
ideas, new guy, propane injection, subaru
