Old 03-11-2013, 06:43 PM   #21 (permalink)
Search the AeroCivic thread on the question of heat/coroplast. His exhaust has been fully enclosed for years.
Fully-insulating the exhaust pipe seems to be effective in every vehicle. And it also makes the catalyst reach the optimal temperature sooner
Old 03-11-2013, 08:59 PM   #22 (permalink)
betasniper's Avatar
Red - '01 Honda Insight CVT
Gen-1 Insights
House of Tudor
90 day: 59.17 mpg (US)
Civic Hybrid - '12 Honda Civic Hybrid
Bahamut - '18 Chevrolet Volt LT
Team Volt
Plug-in Hybrids
I think eventually I will insulate the exhaust pipes and attempt a belly pan after skirts and kammback. I think the belly pan may require more effort then the other two. So I'll save it for later.
Also, my engine revs up to 3krpm when in neutral!?!?! but only when not stopped. This didn't happen before. Ideas?
Unplugged the battery and the problem went away.
: Brothers
: Dad's
Old 03-17-2013, 12:15 AM   #23 (permalink)
betasniper's Avatar
Gen-1 Insights
House of Tudor
Team Volt
Plug-in Hybrids
started working on the vacuum gauge mount for the a pillar:
Turning scrap ABS tube on lathe to outside diameter of the gauge:
After being Dremeled to fit:
Front of gauge:
(square thing is camera reflection)
Still a work in progress. Still have to figure out how to route the vac line through saturn firewall.
Name:	1 machining gauge pod.jpg
ID:	12702   Click image for larger version
Name:	1 fitting gauge pod.jpg
ID:	12703   Click image for larger version
Name:	1 gauge pod face.jpg
: Brothers
: Dad's
The Following User Says Thank You to betasniper For This Useful Post:
MetroMPG (03-17-2013)
Old 03-17-2013, 01:31 AM   #24 (permalink)
That gauge pod looks pretty good for something made out of scrap material.
Old 03-20-2013, 01:23 AM   #25 (permalink)
betasniper's Avatar
Gen-1 Insights
House of Tudor
Team Volt
Plug-in Hybrids
Of course now that I have made that, Mom wants to sell my car and won't let me install it! It won't be sold right away but she doesn't want it "damaged." But it seems that I will have about $4500 budget for a "new" car. If I get a 2002 Honda Insight, how long will it take to make back the cost of the car in Savings? (assuming my car is worth $1200 and I drive 4~5k miles/year)
: Brothers
: Dad's
Old 03-20-2013, 01:54 AM   #26 (permalink)
betasniper's Avatar
Gen-1 Insights
House of Tudor
Team Volt
Plug-in Hybrids
Here is how I did mine gauge pod:
Drilled Holes
Cut with Dremel to fit
{no pics here, sorry}
Constantly checking fit on Pillar
{refer to third pic}
Aline gap between gauges protrusions with hole:
Test fit pod to pillar to see fit again:
What should have happened next:
Cut hole for passing vacuum line and light wires in A pillar
Glue pod to pillar with amazing goop marine/rv/automotive/plumber/any really. (needs to be a glue that is flexible enough to fix plastics)
Attach wires to dimmer switch
attach vacuum line to manifold (somewhere close to the intake runners is preferable)
Reinstall trim in car
Enjoy!
And other gauge pods I made turned:
Name:	2 Roughing Gauge Pod.jpg
ID:	12720   Click image for larger version
Name:	2 Finished Gauge Pod.jpg
ID:	12721   Click image for larger version
Name:	2 Gauge Pod Fit on Pillar.jpg
ID:	12722   Click image for larger version
Name:	2 Other Gauges.jpg
: Brothers
: Dad's
Old 04-04-2013, 02:18 AM   #27 (permalink)
Hi I am also a new member in this forum, interested in this discussions and want to share my thoughts and views.
