12-12-2013, 02:09 AM
#11 (permalink)
PSmodder lurker
The Following User Says Thank You to botsapper For This Useful Post:
12-12-2013, 02:21 AM
#12 (permalink)
Lots of Questions
Oh that stance!
So what's the miles per tire on that, like 100?
Don't forget to like our Facebook page!
Best EM Quotes:
Originally Posted by aerohead
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
12-12-2013, 04:03 AM
#13 (permalink)
Eco-ventor
I'm hoping to see one that has the front wheels of the ground some day.
12-12-2013, 09:27 AM
#14 (permalink)
Master Novice
Okay, no huge grille.
Will a bigger airdam compensate for lack of grillishness?
I'm not sure how "mini" this thing is, or if it ever was if it still qualifies. After the first quarter-ton of fiberglass geegaws, I think such minutiae as "mini-" ness goes out the window.
Those are some serious side skirts, but all the benefit goes away when you get to the double sized (!?) rear wheel well.
12-12-2013, 11:28 AM
#15 (permalink)
Rat Racer
No, that's a full sized van. You'd expect the aero elements to be bigger.
Originally Posted by sheepdog44
Transmission type Efficiency
Manual neutral engine off.100% @∞MPG <----- Fun Fact.
12-12-2013, 12:14 PM
#16 (permalink)
How well could the pink van plow snow?
12-12-2013, 12:44 PM
#17 (permalink)
Rat Racer
Zambonis don't plow.
12-12-2013, 01:35 PM
#18 (permalink)
Originally Posted by jeff88
Oh that stance!
I dunno, but I recently saw a Civic that was "stanced" like that on the side of a rough road. It looked like the tire popped off its bead and lost all the air pressure.... which dropped it all the way to the ground and tore up the ground effects. The owner was looked very perplexed as I drove by. I presume he was thinking "how the F do I get a jack under it...?"
12-12-2013, 03:53 PM
#19 (permalink)
Rat Racer
Plenty of room under the outer edge of the rim!
The Following User Says Thank You to Fat Charlie For This Useful Post:
12-12-2013, 04:56 PM
#20 (permalink)
out the window
At least they're generous to provide refreshments at the front 'bumper.'
