Old 02-12-2010, 12:31 PM   #1 (permalink)
PaulH
MPaulHolmes's Avatar
Open Source high power DC-DC converter
Go Williamson Go! Williamson is making an open source DC-DC converter. 14v out, 90amp. That should run just about everything! He's going to post his progress here.
kits and boards
Old 02-12-2010, 01:36 PM   #2 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Holy moly!
I'll be watching...
Old 02-12-2010, 04:50 PM   #3 (permalink)
What topology does it use? Dual switch forward? Full bridge? Something else?
I think 90A is a bit overkill for a well-designed EV, unless you're going to run something like the A/C. Even then, it's better to design it to directly run those from the main pack.
I'm working on a power supply that converts 340v DC (voltage doubled 120v AC) to 12-15v DC at up to 35A for IT use. I'm planning for a minimum of 80% efficiency at half load. The standby power usage is currently only 1/8w and I'm planning for less than 1w idle power usage. It will have a control interface that will allow a BMS/PMS (Battery/Power Management System) to control its output voltage and current limit as well as turn it on and off and monitor temperature and output current. (It will default to outputting about 14.4v at maximum current limit if the control connector is disconnected.)
It could be used in an EV if the nominal pack voltage is 240-288v. By changing the transformer turn ratio and using different primary inverter components, it can be redesigned for just about any practical input voltage.
If America manages to eliminate obesity, we would save as much fuel as if every American were to stop driving for three days every year. To be slender like Tiffany Yep is to be a real hypermiler...
Allie Moore and I have a combined carbon footprint much smaller than that of one average American...
Old 02-12-2010, 06:55 PM   #4 (permalink)
EVVette - '71 Chevy Corvette Coupe
This sounds perfect for my corvette conversion. I am planing on running a sealed lead acid battery that I can tuck away and keep charged with a DC-DC converter.
I am planing on running 90 TS 100ah cells for a nominal voltage of 3.2V x 90 = 288VDC. This will rise to 3.8V per cell when charging, this will be 342VDC. Will this cause a problem for the converter??
I look forward to seeing some plans!!
-Adam
www.EVVette.com - 1971 Corvette Coupe Conversion to all Electric!
www.AdamBrunette.com - Machining, CNC, Robotics and Electronics.
You can download RTD Explorer for the Cougar controllers at www.EVVette.com
Old 02-13-2010, 07:00 AM   #5 (permalink)
jackbauer's Avatar
A forward converter would be a good simple option as its unlikely ever to need to exceed the max 50% duty limitation of that design.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
Old 06-06-2010, 04:02 AM   #6 (permalink)
Looking forward to seeing the OpenSource DC-DC become available and integrated into the open BMS, charger, display and controller. Great work to all those involved.
Old 06-06-2010, 04:12 AM   #7 (permalink)
Has anyone considered running the display for all things EV on a android device?
DIY Open Source EV Charger bennelson Fossil Fuel Free 385 12-27-2011 02:46 PM
Any interest in developing an open source fuel economy gauge/computer? MetroMPG OpenGauge / MPGuino FE computer 182 06-25-2010 07:00 AM
Open source PCB design dcb OpenGauge / MPGuino FE computer 39 04-25-2010 09:18 PM
Diesel Power Magazine Disappointment. ConnClark EcoModding Central 16 06-05-2009 10:39 PM
Open Source LEV Controller FrankG Alternative Transportation 1 03-24-2008 03:10 AM
