Old 08-09-2008, 10:49 AM   #1 (permalink)
Send a message via MSN to markweatherill
Oxygen sensor gauge reading at wider throttle openings
I have one of those O2 sensor gauges. It displays a light show of LEDs bouncing back and forth when the engine is running.
Well, at wider throttle openings and low vacuum, the gauge just goes out. At that point I notice a lack of power. In this vehicle it's typically when I'm trying to maintain speed on a hill. Easing off the throttle results in the power coming back and the LEDs come back on.
I guess the ECU is going into open-loop and using a lean fuel map (or something) but why would the O2 sensor appear to stop working?
Vehicle is a Nissan with the GA15DE engine by the way.
Old 08-09-2008, 10:50 AM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Is it a narrowband o2 sensor? If so, the gauge is basically meaningless.
Old 08-09-2008, 11:10 AM   #3 (permalink)
The gauge only shows that the sensor is working, I realise I'm not going to get meaningful air/fuel readings off it. It was installed to replace a 1v voltmeter I was using before.
But it does show, by the lights all going out, that 'something' happens under the above mentioned conditions.
I guess I need to look at the injector pulses to see what they're doing. I have a vintage dwell meter but never hooked it up yet.
Old 08-09-2008, 11:20 AM   #4 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
Well, the gauge is probably telling you that the engine is stuck on lean under high power demand, for some reason, so it isn't entirely useless Try a bottle of injector cleaner in the tank.
Old 08-28-2008, 05:18 PM   #5 (permalink)
Could this be a bad fuel pressure regulator, I wonder, causing simple fuel starvation at very low vacuum?
Honda IACV explained TomO Off-Topic Tech 16 12-21-2015 01:49 AM
VX Info...WARNING: lots of info! TomO Off-Topic Tech 1 01-05-2010 12:39 PM
Throttle sensitivity Formula413 EcoModding Central 13 05-29-2008 04:55 PM
