Old 05-12-2008, 10:16 AM   #1 (permalink)
tasdrouille's Avatar
The Guzzler - '08 Hyundai Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '11 Kia Soul 2U
DIY OBDII to ScanGaugeII cable
I was tired of switching my SGII cable between cars now and then, especially since it's routed behind the console in the Elantra. So, I had a male ODBII connector (J1962) lying around from a dead vag-com ebay cable (VW specific diagnostic tool) and decided to make a 2nd SGII cable for cheap.
Here's the mapping between a standard CAT5 network cable and the J1962 connector
Brown - Pin 16
White/brown - Pin 15
White/orange - Pin 14
White/blue - Pin 10
Orange - Pin 7
Green - Pin 6
White/green - Pin 4 and 5
Blue - Pin 2
Facing the connector with the wide side up, pin 1 is in the upper right corner.
You could even make a SGII cable for next to nothing. If you don't have the male connector at hand you could use a junkyard female connector, extend some flattened pins made out of solid conductor power wire and tape it with the other male connector in your car.
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 05-12-2008, 11:06 AM   #2 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
This is good info.
I'm fuzzy on your last suggestion about using the junkyard male connector. Could you elaborate?
Old 05-12-2008, 11:24 AM   #3 (permalink)
I edited my post. I had the male/female part backwards. Here's a pic I snatched from a pdf of someone who made a female connector. The SGII compatible cable will need more pins though.
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1041 07-28-2014 09:19 AM
DIY - Water Injection Stormin' Norman DIY / How-to 46 12-28-2012 12:48 PM
DIY: OEM VX PCV and Info TomO DIY / How-to 4 04-02-2011 09:38 AM
DIY - Basic Fabrication trikkonceptz DIY / How-to 9 05-02-2008 11:10 PM
DIY - Wire Tuck SVOboy DIY / How-to 4 01-25-2008 02:14 AM
