Old 06-07-2012, 07:58 AM   #731 (permalink)
nlc
Paul, what is the max current you will do with your controller ? Surely above 200A ? Do you think 600uF on the DC bus will be sufficient ?
I will maybe developp a 700V / 200A AC controller in next month, and DC bus capacitor really becomes the most expensive part of the controller
Old 06-07-2012, 08:36 AM   #732 (permalink)
PaulH
MPaulHolmes's Avatar
Hi nlc! I'm hoping for 200amp. My friend's 3 phase controller uses 760uF, and is rated for 400ampRMS and uses a DC bus of 330v. It does cause ripple from the batteries, but works very well. He also did one that is rated for around 200ampRMS and uses 380uF. So, rather than basing anything on math, I'm just basing it on him doing it and it working. haha.
It's all assembled, and now I'm testing all the control board's features.
700v 200amp would be awesome!!
kits and boards
Old 06-07-2012, 08:45 AM   #733 (permalink)
nlc
It's a commercial controller or he build it himself ?
I believe the ripple is less important when using FOC, because of the simultanous PWM on 3 phase with PWM configured in centered mode.
Ok thus the 400A controller is diy too !!
No really other solution, I never find magical formula to choose the capacitor value. I believe the most important thing is the ESR, not the total capacitor value.
Old 06-07-2012, 11:00 AM   #734 (permalink)
I have 600V 5600uF capacitor. Can I use that? Is it too big?
Old 06-07-2012, 11:16 AM   #735 (permalink)
PaulH
No such thing as too much!! But the ESR IS THE problem
kits and boards
Old 06-07-2012, 11:39 AM   #736 (permalink)
nlc
Don't forget the precharge
The Following 2 Users Say Thank You to nlc For This Useful Post:
MPaulHolmes (06-07-2012), mrbigh (06-07-2012)
Old 06-11-2012, 06:36 PM   #737 (permalink)
yes you are right, it will need lot of precharge time.
Can you give me schematic of this project? Thank you.
Old 06-12-2012, 05:13 PM   #738 (permalink)
PaulH
Absolutely no stinking mistakes on the AC control board or driver boards or power board. This has never happened. haha. All the safety features work perfectly. I finally assembled the whole thing, and tested the drive section without anything hooked up to the 3 phases. The -8v to 15v is working very well. the poor igbts are being pile-drived into submission on turnoff. haha. I'm going to do a video showing what the pwm signals of each of the 3 phases look like for V/Hz control. It's pretty interesting.
I have one major problem. The AC motor that actually has an encoder is only good up to like 1 amp per phase. haha. I feel fairly sure that it won't be sufficient resolution to test the FOC code on that motor. The big fat motor can handle higher amps, but the motor post is too big for the encoder from the company that I've ordered from before. So, if anyone knows of a good "encoder" company I'd be happy to hear about it, yo!
Yes, I'll post all the schematics once I see that it doesn't blow up under load. haha.
And yes, that other controller was a commercial design, but was very clean, using an intelligent power module from Powerex I think.
kits and boards
The Following User Says Thank You to MPaulHolmes For This Useful Post:
sawickm (06-12-2012)
Old 06-13-2012, 05:41 AM   #739 (permalink)
nlc
You are right, 1A is very low current, resolution will be very low. What chip are you using for hall effect current measurement ?
If your first goal is to test the controller hardware with high output current, think you can easy test it on your big motor without encoder, just using your FOC algorithm in open loop mode ? In my case, I do this by simulating a rotating rotor position at the speed I want instead of real motor position. The result is a rotating field on stator with the speed I want and with the current value I want depending on my current consign. It permits to send a lot of current without load on the motor, thus testing the full current capacity of the controller without a brake on the motor.
I think you can do the same by simulating the output speed value of a virtual encoder ?
For the PMAC 700V/200A controller I will maybe have to develop in next month, I will probably use powerex products. They have very good thing at very competitive price !! As an example, a dual IGBT module in 1200V/300A configuration costs 135$ : Darrah Electric
They also propose the corresponding isolated driver board for 14$ : VLA503-01 Powerex Inc | 835-1065-ND | DigiKey
and the isolated supply for 14.7$ : http://www.digikey.com/scripts/DkSea...-15242&cur=USD
Thus total cost become 3x150$ + 6x14$ + 6x14.7$ = 622$.
"Just need" to develop the 3 small board to connect 2 drivers module and 2 corresponding isolated supplies, the control board, and the DC bus capacitors filtering board.
Really interesting I think to quickly develop a 700V/200A AC controller when very low price is not the first consideration !!
The Following User Says Thank You to nlc For This Useful Post:
MPaulHolmes (06-13-2012)
Old 06-13-2012, 12:51 PM   #740 (permalink)
jackbauer's Avatar
Paul , what about replacing one of the bearings in the big motor with an encoder bearing?
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
Paul & Sabrina's cheap DIY 144v motor controller MPaulHolmes Open ReVolt: open source DC motor controller 7381 08-02-2023 10:55 PM
Contest! Name Paul & Sabrina's controller MetroMPG Forum News & Feedback 120 10-22-2011 01:59 PM
