Old 05-20-2009, 04:44 PM   #1331 (permalink)
2k2Prot5 - '02 Mazda Protege5
90 day: 33.82 mpg (US)
I actually haven't seen the source code in a while. I'm not sure if he is still doing the "one per cycle" increment/decrement. That wouldn't really be PI. State space, i think, is what we should really be using, but that's new tech and a little tricky. probably not worth the minor benefits.
Old 05-20-2009, 05:24 PM   #1332 (permalink)
PaulH
MPaulHolmes's Avatar
I changed the pwm so it's effectively 14 bit, although it really is only 10 bit. I use an auxiliary variable to store the "fine" PWM duty, and each time it is updated, I shift that value down 4 bits, putting it in the range 0-1023. It makes for very smooth driving at near 0 rpm. I would definitely describe the throttle as a bit squishy as JayC was saying. I might try a PI loop again. It was an abysmal failure last time. The greater PWM resolution I bet will fix that problem. Or I'll just do something like "squishy if change in throttle is small", "fast and snappy if change in throttle is large". That would still allow for smooth takeoffs, and I don't think would require a PI loop. Right now, it feels perfectly smooth, and stopping is pretty quick (4 times faster to slow down than to speed up), but not instantaneous, because it made for jerky driving each time I would take my foot off the gas, I mean throttle haha.
I'm going to get that PI loop working. It will be nice to have when RPM feedback is implemented. I have a little hall effect rpm thing that that was $6 that I haven't tried out yet.
kits and boards
Old 05-21-2009, 12:11 AM   #1333 (permalink)
Paul, can you measure the rate of change in the throttle position input and then feed that value in to a sensitivity multiplier? sort of like what Microsoft does for their mouse pointer acceleration. that would allow the driver to control whether it reacts smoothly or aggressively and passenger
"Experience is something you get right after you need it !"
http://www.diyelectriccar.com/garage/cars/143
http://www.diyelectriccar.com/forums...tor-32083.html
Old 05-21-2009, 12:26 AM   #1334 (permalink)
PaulH
Hey BlackPanther! That's exactly what I was trying to do a few minutes ago, until I realized that I just put the last diaper on our poopy son, so we just got back from Walmart. Now I'll go back to trying out that idea. Thank you! It's too dark to go drive and test it out, so I might do that tomorrow.
Well, I tried it tonight. I couldn't wait. Much more responsive, like a regular car, but a hair wiggly at near 0 rpm (lholding still up a steep hill). With incrementing the fine duty by one, it's VERY smooth, but a bit mushy. I like the term mushy! I'll lower the sensitivity some more to see what happens TOMORROW! HAHAHA!
kits and boards
Old 05-21-2009, 02:32 AM   #1335 (permalink)
Hi Paul this is really great stuff you are doing, this has renewed my interest in EV again.
I'm a good fabricator if I can help some how let me know, I'm local to you, Lake Tapps near Auburn.
Torry
Old 05-21-2009, 08:12 AM   #1336 (permalink)
Paul, something is fundamentally wrong if you can't get a smooth acceleration out of a PI loop. Can you detail your current and throttle sample rates and filtering methods as well as your PI loop frequency and P and I values and how you came to them?
Old 05-21-2009, 09:56 AM   #1337 (permalink)
PaulH
Thank you I B RACIN! I used to go swimming at Lake Tapps, since I grew up in Auburn. That's weird. Thank you for your offer!
Matt:
I have no doubt that there is something fundamentally wrong with my crappy PI loop. It's a piece of junk right now, but I'll try to make it a bit more clear, and then attach it here for you to look over, maybe tonight. I choose my P and I values by starting with I = 0, and P small (but not that small, only 1/64 I think), then gradually incrementing P until "I noticed overshoot", which was a joke because at the time everything was so noisy that it was a mess. Then I was supposed to back off a bit, and then gradually increase I until more overshoot or oscillations. I haven't tried it with the filtered current that I have now. I really need to try it, then I'll ask you guys what I'm doing wrong. IT was a long time ago since I tried it last, and a lot has changed softwarewise.
kits and boards
Old 05-21-2009, 10:02 AM   #1338 (permalink)
Okay, i'll just leave you alone you've got more important issue to worry about than the fine details of the foot-to-road dynamics. If there's one major lesson I've learned in engineering - perfect is a dream, comprimise puts products on the market.
Old 05-21-2009, 10:56 AM   #1339 (permalink)
Corolla bandit - '05 Toyota Corolla CE
This project is looking really good. I was hoping I could help out with the code. Paul , could you put it on the wiki or - even better - in charlie_fd's svn repository (/trunk - Open ReVolt - Trac). It sounds like you've been getting a lot of help with the hardware side, let's get the same number of eyes looking at the software.
Old 05-21-2009, 12:11 PM   #1340 (permalink)
PaulH
I'll attach the stuff to the thing from Adrian once I figure out how to send files there. I logged in, but I don't know how to send files. I'm going to try to fix that stupid PI loop now.
kits and boards
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 3480 05-04-2022 05:43 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 04:10 PM
