Old 10-25-2009, 02:52 PM   #2501 (permalink)
PaulH
MPaulHolmes's Avatar
That's awesome joe!!!
kits and boards
Old 10-25-2009, 03:41 PM   #2502 (permalink)
jackbauer's Avatar
Sounds like a peak detector circuit. Should work well. I must do something similar.
Old 10-25-2009, 07:47 PM   #2503 (permalink)
Joe
Originally Posted by MPaulHolmes View Post
OK, First I made the awesome little circuit. Then I precharged the caps and watched on the dedicated volt meter what the max voltage was from Drain to Source.
If 7 is the spikes above max voltage, then it's officially safe to drive around at 193v. hahahaha. Just kidding.
Ok, so I got off my butt and did it too and got something similar. Pack started off at 154V according to the test meter while my voltmeter in the car showed 152. In 3rd gear from a stop, it's easy to hit 500A with little voltage sag. The most I got from the test meter was 161V while the pack sagged to 148V on my car meter. So, I guess to be conservative, we could say that's 13V above pack voltage when considering voltage sag. A pack of lithiums won't sag as much (supposedly).
ReVolt AZ testing thread:
http://ecomodder.com/forum/showthrea...ting-9325.html
Old 10-25-2009, 10:28 PM   #2504 (permalink)
PaulH
That's so wonderful I can hardly stand it! Thank you Joe!!! Not bad. 13v isn't toooo much. I feel so much better now. The voltage spike magnitude is a linear function of di/dt. dt is the same each time, so I think a 700v controller would have a spike of 18.2v to be conservative. So, with a lithium pack with no sag, assuming the starting voltage was 154v, it should get up to 172.2v, still safe. PHEW!!!
kits and boards
Old 10-25-2009, 11:07 PM   #2505 (permalink)
PaulH
I wrote an updated help file for the DIYer that wants to make their own controller. It's based on the kit, but it would be pretty easy to adapt the process to something else I think. I lost a lot of all the good changes that Fred Good made, since the process has changed so much. Let me know if there is anything unclear.
Motor Controller directions
kits and boards
Old 10-26-2009, 10:40 AM   #2506 (permalink)
jackbauer's Avatar
Little more progress today getting the parts in the box for a trial fit.
ID:	4607   Click image for larger version
Old 10-26-2009, 01:27 PM   #2507 (permalink)
PaulH
OK. that's awesome. I'm not going to lie...
kits and boards
Old 10-26-2009, 11:13 PM   #2508 (permalink)
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
And just because this is Paul's thread...
I haven't heard any Oprah jokes in a while, but I think there is some kind of method to the madness.
Dr. Phil just became the leader on Jay Leno's Green Car Challenge.
I believe we have reached ONE DEGREE OF SEPERATION between Oprah and electric cars!
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 10-26-2009, 11:27 PM   #2509 (permalink)
PaulH
hahahaha! Go Dr. Phil!!! Go!!!!!
kits and boards
Old 10-29-2009, 06:22 AM   #2510 (permalink)
jackbauer's Avatar
Just running a few bench tests with the starter with the scope across M- and B- i'm getting some fast voltage spikes at turn off. Waveform looks quite clean apart from that. Thinking of putting a snubber on the igbt. Any thoughts?
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 3480 05-04-2022 05:43 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 04:10 PM
