Old 01-05-2011, 08:55 PM   #4171 (permalink)
EVVette - '71 Chevy Corvette Coupe
Originally Posted by apowers View Post
here is the link to a programmer AVR Programmer
here is another you will need avr dude with it.AVR Tutorial #2
The first link in this is one of the best and simplest programmers Ive seen. Its very easy to make and can be done by anybody that can solder. Also, that it includes a tutorial to how to program with it is fabulous.
I think somebody should add this to the wiki. It will be very handy in the future.
Now, the million dollar question, Does anybody know of a tutorial and schematic like this to program the dsPIC chips?
-Adam
www.EVVette.com - 1971 Corvette Coupe Conversion to all Electric!
www.AdamBrunette.com - Machining, CNC, Robotics and Electronics.
You can download RTD Explorer for the Cougar controllers at www.EVVette.com
Old 01-05-2011, 10:00 PM   #4172 (permalink)
The ready-to-use programmers are a little over $10 on FleaBay. Or you can buy an Arduino board, albeit with the need to make up your own cable. Or go the whole way with a Bus Pirate -- about $30.
Old 01-05-2011, 10:08 PM   #4173 (permalink)
bootloader
Great info everyone! I feel like the wheels are starting to roll again with my conversion. Does anyone have the hex code or whatever it's called for the bootloader? Am I writing that correctly?
jake
Old 01-05-2011, 10:12 PM   #4174 (permalink)
jake
Jake,
You can visit my website at Index of /firmware for a full archive of the current and all previous firmware. Current version is 1.11b. In the folder, there is another folder called hexfiles-m168, in this folder there is a file called coug-unified-16k.hex . This is the file for the atmega168 micro that contains the bootloader and the firmware running at 16khz output frequency. You just load this one file and your all set to go.
-Adam
The Following 2 Users Say Thank You to adamj12b For This Useful Post:
deodeo (04-16-2012), Nevyn (05-03-2013)
Old 01-05-2011, 10:16 PM   #4175 (permalink)
Gratitude
I just feel so grateful that you guys are available to help!!!
jake
Old 01-06-2011, 04:38 PM   #4176 (permalink)
EV Connoisseur
Hi,
I've been searching the wiki for the PCB layout files and it seems like the links that are there are broken:
Full archives from MCUDOGS inc schematics, pcb files and software:
Power board V1d altium files --mcudogs 15 Sep 2009 (EDT)
Controller board V2d altium files --mcudogs 15 Sep 2009 (EDT)
Is there an alternative location, or can someone attach the pdf's with the pcb layout?
Thanks.
Old 01-06-2011, 04:49 PM   #4177 (permalink)
Flores, are you trying to find out where to place the components? If so, I had that problem at first. In that case, you just use the alpha-numeric ID for each component on the BOM(component list, such as "C11") to match the component number on the PCB. Hope that is your issue.
Jake
The Following User Says Thank You to lespaul109 For This Useful Post:
flores (01-06-2011)
Old 01-06-2011, 04:52 PM   #4178 (permalink)
EV Connoisseur
Thanks..
But I need to make the board first.. so I really need the layout files.
Old 01-06-2011, 04:55 PM   #4179 (permalink)
I think I have the files that you need, send me your email.
jake
Old 01-06-2011, 04:58 PM   #4180 (permalink)
EV Connoisseur
Cool.. please send them to feken[at]itq.nl
Can't PM you because of my low post count..
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 3431 05-04-2022 05:43 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 04:10 PM
